Tyres for a 99 De Luxe
After a few slides I have decided to bite the bullit again and try to find some tyres to fit the 99. I would like to go for the Avon road Riders but need to find out the fitted width of the tyre on a WM2 steel rim.My previous purchases ( from a well Known Norton site were too wide to fit and clear the enclosed chaincase) Probably a 90 90 front and rear?. Do they do a rear in that size.?.
Roadriders are indeed great tyres. At the moment I have Avon Speedmaster ribbed 3.00x19 on thefront, SM MkII 3.50x19 on the back and they perform admirably. I am not known fortrepidacious cornering...
What are your current tyres? The only tyres which have frightened me are Dunlop K70s which when fitted on the back have caused some horrible slides.
I have a Roadrider 100/90-19 fitted to the rear of my swinging arm ES2 and have just measured it at 105mm wide. There are no clearance problems and I think a 90/90 tyre on the rear would be a bit narrow.
The 100/90-19 is equivalent to the old style 3.50 and 90/90-19 equivalent to 3.25-19. It would have used a 3.50 when new.
They are good tyres The Avon SM is archaic in comparison. It does look the part more than the Roadrider but if you're going to ride the bike rather than look at it the Roadrider is a better and safer choice.
Ian
Thank you Ian, that's exactly what I need. I have the standard Avon ribbed and SM Rear on and they are old .I am usually in the company of an Atlas ridden by a Police Motorcyclist and a 700 cc Suzuki MT07 so I do have to push it a bit!.Don't think there is room for 105mm but we will see.How do the RR's cope with muddy gravelly leaf strewn lanes? (Vintage club runs).
Just been down and checked, a 350x19 SM is 90 mm and I dont have enough clearance for an extra 7mm on the case side. The only other thing to check is the offset just in case I messed it up ,Don't think so as it tracks straight with hands off and corners the same in both directions.Those enclosed case mounts are the problem ,perhaps a longer rear chain would position the tyre further back and help.A lower profile tyre may also help this but would lower the gearing a bit.
I have a 90/90-19 AM26 on a front WM2 (It shouldn't make a difference if it is an original rim or alloy) and it measures 93.2mm - Unfortunately, they don't seem to list a 90/90-19 for rear fitment. Maybe Avon could advise if the front type is acceptable on a relatively low-powered machine.
An internet search hasn't shown any 90/90-19 rear fitments...it might mean sticking with a 3.50 if the bodywork is that restrictive but even the Dunlop K70 and the Avon SM are now made in modern compounds so will be an improvement.
Hi Richard, They don't appear to do a 90 90 rear, and they are not reversable I understand .
If you look at the link posted earlier you'd see Avon do a 3.25" x 19" universal, width 3.9" (99mm), same as the 90/90 x 19" front, but 0.3" larger on the radius.
Hi simon, Its too wide. Norville re-furbished a DL and put modern tyres on it somehow. Perhaps the wheels were pointing in different directions,Its just possible then!.
If you want a 90/90 front Roadrunner - I have a new one in the shed because it won't fit between the pre-1964 Roadholders if it has original tinware-(which is the whole point of the De Luxe.It brushes the mudguard on both sides. It would no doubt fit the 1964-onwards forks.The 100-90 is very tight against the front left of the rear mudguard but seems to fit. Just. Most 'standard' (as opposed to De Luxe) Slimlines I have seen have the front left inwards-shaped square bit (about 3" x 3") of the rear guard (the bit that turns just inside the swing arm) cut away to give more tyre clearance. Almost certainly by the factory - since they all have it - and it usually looks a bit rough as if they did it with tin snips after the pressings arrived at the factory.
And that's why my 99 Deluxe (though it no longer looks much like one) ended up with the Speedmaster/SM combination whilst my BSA has Roadriders - originally bought for the 99. The BSA has plenty of clearance for the tyres, unlike the 99.
hello well I found there all right on my 650 and they grip well they see 110 too on a runway Breghton east Yorkshire
Thank you David,thats the other piece of the puzzle sorted! , the fronts too tight as well for a 90 90. Looks like I'm back to the old speedmaster/SM combination ,The only good thing in their favour is they seem to last forever but how long does the rubber stay supple? ,The deteriation is so gradual its hard to tell. I would say 10 years ,How often do you change yours Gordon?.
Try a 360x19 tt100 they are front/rear fitment
Hi Alan. ,TT100 might just fit the rear but nothing for the front!. Just checked the dates on my 250 Ducati tyres and they are 15 years old. The Nortons may be older,GULP!.
I change tyres when they wear out or show signs of age. The ones on the 99 are about 5 years old and are low on tread and due for a change.Too many bikes in the shedthese days. When it was just the 99, annual or even 6 month tyre changes were the norm. Richard is right to point out that old-style tyres are now made from modern compounds. You should be pleasantly surprised with the effect a new pair of tyres has on the bike.
In one of the Classic mags, one contributor proudly announced that he had found and fitted a pre-cling rubber tyre to the front of his Norton. I keep checking the obituary columns. Just the thing that MoT tests where intended to prevent. OK, for the pedantic, MoT tests don't check the age of a tyre, but it's hard to imagine a 60 year old tyre doesn't have cracks.
True confessions time. I have briefly tested a Rudge with 60 year old tyres BUT it will get new tyres before it is fully recomissioned and put back on the road.
Sounds like a good excuse for a competition.Who is riding on the oldest tyres?. I never win anything, but could win this!. Whoever wins agrees to scrap their tyres immediately and fit new. Might just save someones life. Whats an Ulster with a few wrong bits on it worth Gordon? Looking at one now.( I think I might have some spare tyres for it!)
A rear Roadrider lasts me no more than 4,000 miles - cost is approx. £70 (I fit and balance them myself), so that's 1.75p/mile. In comparison fuel costs approx. £5.00/50miles = 10p/mile.
On average I get through two rears and one front a year, so age is not a factor. Tyres obviously play a big part keeping you out of hospital and are very cheap in my opinion, considering what they do. If I wasn't doing the mileage I'd probably change them every 3 years which is approx. £23/year, so that's 6p/day. Too much to stay safe?
P.S Sorry, times 2 = 12p/day.
Don't bother to enter the competition Simon!. I think we should all post the dot codes on our tyres, some people may be surprised. I've bought a set of the old Avons as nothing else works size wise.
How often you change tyres must depend to some extent on how many bikes you have.And on any motor vehicle, the speed you can go round corners (and breaking distance) surely varies as much with road condition as it does with tyres? There is a perfectly reasonable theory that says that poorer grip and poorer brakes result in lower speeds and less energetic accidents.My experience as a passenger in a vintage racing car was of terror that the relatively modern tyres were so much grippier than those from the 1920's that the car was now far more likely to turn over whereas with older tyres it would much more safely and predictably slide sideways.I like the definitions:"Road Holding" is to do with how fast you can go round corners. "Handling" is to do with how often you come to grief. I suspect the ribbed front is better for Handling, and RoadRunner maybe better for Road Holding.Is that reasonable? My featherbed steering feels more nimble with 3.00x19 ribbed rather than 90-90 'modern' Roadholder.And as for setting a fixed age: I went into KwikFit to ask them to check why a car tyre pressure looked to be low. The youth looked at the wall and declared that they would not consider repairing the tyre because it was more than three years old. Needless to say I shall never go back there!
There is a perfectly reasonable theory that says that poorer grip and poorer brakes result in lower speeds and less energetic accidents....
The difference between two motorbikes (one with poor brakes and tyres, the other with good brakes and tyres) travelling at 30mph and performing an emergency stop, in the wet, is, if the one with good brakes and tyres manages to avoid an 'energetic' collision, then the other one probably wont.
A tyre manufacturer tested tyres that had been stored for 5 years and could not detect any falling off in performance against new tyres. A lot seems to depend on the quality of the product.I have just scrapped some 20 year old 25000 mile tires that were completely free of any visual defects and looked about i/3rd worn.I just was not comfortable with the worry of failure.I worry more about the competance of many of my fellow road users who appear to have no road sence at all.
I've been using Mitas on my bike, 3.0 HO1 on the front and HO3 on the rear. They have done over 3000 miles and have been excellent. Need to replace the rear over the winter. Having changed the front mudguard I plan to fit HO1's in 325 and 350 - currently available from Wyldes for £86 for the pair including tubes and delivery!
I have a choice between a newTT100 rear thats been stored for 5 years and a new speedmaster front, or a new SM rear with the speedmaster. I would like to use the TT100 before it ages any more but has anyone experienced this combo?.
I recall running a rear TT100 with a ribbed front back in the 1970s. From memory, it worked fine. I'd suggest try it and see...
We have been through this question before, Robert. You can fit the excellent 19 inch Avon 90-90 front tyre if you want to. (WM2 Rim) You just need to swap the standard bridge with a stainless Commando bridge and drill the appropriate holes in the new thinner bridge. This is what I did with my 1960 99 (Still waiting for my V5 but maybe tomorrow?)
I can't understand why you can't fit a 100-90 to the rear, went on my 99 no problem on a WM3 stainless rim.
As for your suggested combo: This is what I hope to put on a 1957 model 50. Remember the swinging arm is the same width at the fork but at the pivot is two inches narrower! The tyres are fine as long as you ride steady.
Hi Neil, I'm afraid neither tyres fit. This is a DL with narrow yokes and a narrow deep valenced front guard.Even the correct closely moulded brace can scrape the fork legs. the enclosed chaincase bottom mounts don't allow much more than the 90 mm SM or a 360 TT100 (90mm). A !00 90 measures 15mm wider.I'm surprised the tyre specs don't list the actual width in most cases(though they can be found). Its true that due to the lower profile of the modern tyres they will sit further back in the rear fork,But I made this expensive mistake a few years ago.Could try an old tyre . And a longer chain to get the wheel right back. I would love to fit better tyres but as Gordon and David knows its not on.I have put the SM up against a TT100 and the SM stands about 2" higher so the modern tyre will lower the gearing, reduce cornering clearance and drop the back end, probably slowing the steering too. Need low profile at both ends to avoid this.However the center stand will then work!. What are you doing awake at this time?, My excuse is a curry. followed by a big bar of chocolate.And indigestion.
