Smiths speedometer
I'm servicing the speedo on my 77 mkIII commando on which the mileometer and odometer have never worked. Does anyone know where or if I can source these items complete. The counters are seized on the rails and distorted, maybe sunlight and time. I know of advertised servicing such as Mr Pople but would like to do it myself.
Hello michael , my 63 electra odometer gear is shot ,so i found
a company in new york that said they could refurbish the entire
unit, give them a call - 914-381-3600 - nisongerinstruments.com
good luck - todd stewart
There was a book published a while back about overhauling speedos. It was written by the author of Improving Classic Bikes, so this may be of help to you when you try to rebuild your own one. If not send it to Ashley as he has been repairing those Smith clocks for over 30 years. He has repaired the clocks on all of my own bikes.
In reply to by anthony_curzon
I think the book Anthony is referring to is "Magnetic Speedometer Repair" by Graham Blighe. I can't find any reference in it to the publisher or an ISBN but there is a note that the author's books are available at www.ImprovingClassicMotorcycles,com . Or I seem to recall I got my copy via the VMCC.
HTH.
If the speedo has mileometer and odometer it is most likely a Veglia instrument. You may have a hard time finding anything for these.
If it all gets too much you could do a lot worse than go to Ashley Pople. He certainly knows his stuff. He renovated my mid-fifties ES2 speedo for me at a reasonable cost.
George
This book was self published and I bought my one from the author direct.
The book that you want is Magnetic Speedo Repair, and it is the definitive guide to the repair and calibration of Smiths SSM series speedo's and RSM rev-counters. It is a fix it your self book, and instruments can be calibrated on the bike or on an easy to build rig. It gives full instructions, in every step of the way. No specialist tools are required, just a cycle computer. It was sold or may be still is by the VMCC  under part number B152 and it was £15. The VMCC telephone number is 01283 540557, and their web site is www.vmcc.net
See also www.amazon.com/Magnetic-Speedometer-Repair-Graham-Blighe/dp/B003NGP1F2
