Hi Iâm somewhat of a Norton virgin, and am stripping down a 1952 Dominator 7 and am wondering how to remove the rear plunger units. I can remove the central rods okay (now) but am wondering how to compress the springs to remove. Iâd be grateful for any advice
Doug
Hi Doug - this may be of s…
That's the correct way. T…
That's the correct way. The units will expand by about 3" when the springs are relaxed so make sure you have enough thread on the rod. I cut two penny washers to a D shape with the flat edge going close to the central hole, and used an old box spanner as a spacer to give easier tightening of the nut.
Don't under any circumstances try to remove the unit without using the central threaded bar to compress it - there's a hell of a lot of force locked up in those springs and teeth, fingers etc could easily be lost. It is a fairly scary procedure even with the bar.......
The central bearer bar was immovably seized into the slider on one side of mine and I had to cut through the top shroud then use an angle grinder to cut through the bearer bar to get that side off. I had a new bar made by a very helpful ex-toolmaker.
Previously ian_soady wrote…
Thanks for this, I understand now. The shock gets displaced laterally a bit, just enough to slip a rod and washer/ spacer on either end, but displace too much and the shock explodes across the garage. The D shaped washer is a good idea. I would imagine the bearer bar is quite a tricky bit to machine up with that spiral. Thanks again
Hi Doug - this may be of some help - from Main - Smith reprint of original workshop manual .
These are very economical and highly recommended if you don't have one -
Richard
image-jpg
