Hi. I'm hoping someone can help me find some parts I need to finish my engine rebuild. The parts I need are the pressure release valve and filter assemblies that fit inside my timing cover. The year of the engine is a 1958. I have attached an image of the parts I need.
I have already tried Norvil, RGM, Andover, Russell Motors and the NOC Spares and the internet, but have had no luck apart from NOC who have the external nut which I've ordered.
If anyone has any ideas where I could buy these parts from I would appreciate that very much.
pressure-release-valves-jpg
Peter: Can you list the co…
Previously peter_sinnott w…
Hi Peter, I got one in s/steel a couple of days ago for a 56 dommi 88, part no. 066195A from RGM. All the best Campbell Adie
I think the design changed…
I think the design changed so check you are getting the right one.
Hi Mike I'm not sure wher…
Hi Mike I'm not sure where I could get the part numbers from as the only parts book I have is from Norvil and they only list the earlier ones, but if you could send me the name and number of your Norton parts supplier I could contact them and explain the parts I need. Hi Campbell I have contacted RGM and they only supply the earlier pressure release valve and not the one for my 1958 model.All the best Peter
Peter: All my parts suppli…
Peter:
All my parts suppliers are here in Northern California.
Iwill be glad to do a search for you but I will need the part numbers.
Thanks Mike I will try and…
Thanks Mike I will try and find the part numbers. I do have family in California and I'll ask them to see what they can do. I never thought of looking for these parts in the USA but I'll give it a go. Thanks for your help all the best Peter
Peter-The part numbers are…
Peter-The part numbers are 20287 Filter plug,20288 washer,20280 Filter
20284 Spring Plug,20286 Spring,20285 Plunger
Good luck! Ron
Hi Ron thanks for that I'…
Hi Ron thanks for that I'm sure that will help with hunting down these parts. Believe it or not these small parts are all I need to finish the engine rebuild. All the best and thanks again Peter
Peter: I checked my source…
Peter:
I checked my sources here in Northern California and have had no luck.
Good luck in your search
Peter: I did a further sea…
Peter:
I did a further search and have found the following:
NM20286 Spring $0.95 ea
NM20285 Plunger $1.13 ea
According to their website they are available at:
Raber's Parts Mart in San Jose, CA
www.rabers.com
If you cannot find them anywhere else, look them up and send them an email to make sure that they still have them on hand.
p.s. This is the largers British Parts Supplier in the San Francisco Bay Area and I would consider them to be very reputable.
Also, have you tried finding the parts you need at a breakers?
Hi Peter, I have a spare c…
Hi Peter, I have a spare cover of the same type and its probably complete ,Better to have new parts but if you get stuck I will try to help.
Hi Robert not sure what to…
Hi Robert not sure what to do now I read on the NOC pages that the type of oil cover I have has had problems which is why Norton went back to the old design after 4 years. It may be worth me buying a timing cover with the old/new oil release valves. I'll look into this a bit more. Robert thanks very much for the offer I may still take up your kind offer. Regards Peter
I have the same on my 1960…
I have the same on my 1960 99 and its been no trouble for the past 58 years.
That's good enough for me…
That's good enough for me. If you are happy to sell the valve and filter etc. i would love to buy them. My email address is fastbackt100@gmail.com thanks again for your help Peter
I will be in the dark end…
I will be in the dark end of the shed later and will check whats there.
Hi Peter ,I have found my…
Hi Peter ,I have found my spare timing cover which is complete, how are you getting on with your quest for the valve parts?
Hi Robert not much luck ap…
Hi Robert not much luck apart from dealers I have tried eBay and the last Kempton Park meet, it was bit of a wash out but no luck. I have bought another timing cover with the external valves. So I think I will fit that timing cover. Sorry to have messed you about but thanks for all your help. All the best Peter.
Thats Ok Peter, I am havin…
Thats Ok Peter, I am having a general clear out to make space for a workshop. Can't carry on working off the corner of a busy washing Machine!.
That cannot be easy when i…
That cannot be easy when it's on the final spin.
Peter:
Can you list the component part numbers?
With the numbers I can check with my local suppliers.
