Evening Gents,I'm trolling around for a Pressure Release Ball Spring (A2/16) as well as the Presure Release Ball Screw (C2/17) for my '48 ES2. Both are well past their use by date
Anyone know of a source?Cheers from HalifaxB
Hi, Both of these are avai…
Thanks for the tip. I've…
Thanks for the tip. I've sent them an email.
B
Just out of interest hoe d…
Just out of interest hoe did you get the screw undone?
dan
Evening, In my case it loo…
Evening,
In my case it looked like someone tried to remove the screw with a dull chainsaw. Already beyond re-use I warmed up the cover a bit and turned the screw out using a large slot screwdriver. It clearly had been punched in place on several occasions. The good news is the cover is not damaged so once I find a replacement screw/spring/ball I should be good to go.
My email to Russell Motors bounced back. Anyone know their correct email address? Or perhaps they decided the Internet was a fad that would fade away? I used: spares@russellmotors.co.uk.
Cheers from Halifax,
B
From Memory they don't re…
From Memory they don't respond to emails very well...best to call.
Both of these are availiable from :Russell Motors - 125-127 Falcon Rd, London SW11 2PE, United Kingdom. +44 20 7228 1714
I purchased then just 2 momths ago. The spring is from the competetion engine, and will need 2 turns out. rather than the 1.5 for the std spring.
Cheers Steve
Australia
