New Member, old Commando
I'm going to need your help restoring this Mk1 Fastback, Basket case and im not sure who is the basket case - me or the bike!.Barn find all numbers look to be 50 years old and undamaged,however there is somthing strange frame g/box 131029 but engine eleven numbers higher? I took the chance to buy her anyway, but can anyone throw light on this issue? Thanks.
Few Commando's of that age will have the original matching engine and frame numbers. Many will have been trashed and had replacement engines from the nearest breakers. You could consider yourself lucky to have an engine only 11 numbers away from the original. What should concern you is the frame and whether it is a "widowmaker" without the extra tube under the spine. You say it is a Mk1 that puts it at about 1969, a mere youth at only 45 years old.
Thanks David it is a 'widowmaker' without the extra tube, I could not find any damage though.I assume I should put in the tube? In my youth I used to ride one - I'm a lucky man then.
I would look for a good frame maker and get the extra tube welded in. This will lead to a noticable bow in the spine tube but that is normal on a Commando. You also need a threaded boss on that new tube to fit the head steady and finally, fit the box shaped head steady from the later Commando. The early ones are prone to cracking and welding will just move the crack elsewhere.
Hi Wayne
Nice find. I just got a 68 from the US. All matching numbers 128372. I have done the mod on the frame. Just have a good look at the down tubes. Mine looked good but I striped it and found the R/H one was cracked about 3/4 of the way around so would definately recommend doing the frame if you want to ride it.
Post some pic. Would love to see it.
Enjoy,
Dean
Hi Dean & David Can you tell me where i can get the later box head steady and boss from.Thanks.
The box section head steady should be available from Andover Norton but the frame boss would have to be fabricated by the man who fits the tube. It's just a threaded boss (5/16" UNF) through the tube but in the correct position. I'll come back to you later with a position measurement. (might even be in the haynes manual)
Thanks david i can work it out from hear.Nice bike Dean must be one of the first commandos made,Thanks for your help.
Hi Wayne
still have a long way to go before it's a "nice bike" hasn't run since the 80's and has had a bit of the chopper treatment in the 70's. Nothing that can't be fixed.... With time and money.
image-jpg
