anybody have the correct length for the 4 different lengths. I know there's inner/outer disc side and the same on opposite. this is for front disc wheel
These are the dimensions f…
These are the dimensions for some spokes I bought, they fitted well and were stainless.
9G*202mm(90degree) offset 6.9mm 10 off9G*202mm(80degree) offset 6.9mm 10 off8G*195(90degree) offset 7.35mm 10 off8G*195(80degree) offset 7.35mm 10 off
The factory manual has very similar dimensions but does not specify the length so you could take the length from the table and use the data from the manual for the gauge and offset but if going for stainless you need to drop the butted spokes and go 8G to add some strength. The offset is the distance from the spoke head to the bend.
