The Slimline Model 50 exhaust pipe pn: 23290 carries a different part number that the pipe for the Slimline ES2 :pn 23290
Can anyone state what the differences are?
I have been told that the Model 50 pipes are 1-5/8" OD whereas the ES2 pipes are 1-3/4" OD
The silencers for both bikes have the same part number pn: 22121 and I believe that the inlet for this silencer is 1-5/8" such that the pipes are reduced at the discharge end.
I would think that the only differences in the pipes should be that the pipe for the Model 50 has a shorter vertical run than does the pipe for the ES2.
Sorry to be a pest about all this, I'm just trrying to get it right.
p.s. weather here today in the San Francisco area is about 60 deg f. and the robins have shown up. It must be spring! Dry roads on the way.
HI Mike AFAIK, you are cor…
Previously wrote: HI Mike…
HI Mike
AFAIK, you are correct, it is just the vertical height that differs, year by year the ES2 and M50 had the same pipe diameter, and the singles went to a smaller pipe size in 1958 or so, I think (someone will correct me if I'm wrong) just so that they could use the same silencers (mufflers) as the twins, which were massively outselling them by then, (although I have seen a 1 5/8ths pipe with a swaged-down end, but I don't know if it was an original one, or what it came off) but when the singles went into the featherbed frame slightly later, the smaller pipe provided more clearance to the frame downtube, so you probably need the smaller pipe. Norton Motors may have been planning ahead but I doubt it, I do know for certain that the pipes for the wideline singles have the same bend but are shorter on the horizontal section, so on a slimline the pipe won't reach the silencer if you use the downpipe off a wideline.
There were quite a few changes over the short life of the Featherbed ohv singles, and little information because at the time I don't think many people were interested in them, mostly they got what the twins got.
There is much talk about bend radii etc, but for my money if you can get someone to bend you one up that aligns with the port well enough to seal, doesn't foul the frame and then lines up with the silencer, then thats good enough.
Good luck,
cheers,
Niall
Sorry Mike I meant to write that I have seen a 1 3/4" downpipe that reduced to 1 5/8" at the end, but as I say what it was, I don't know, could have been Inter for all I know.
HI Mike
Good luck,
cheers,
Niall
