Would anyone know where I can get +0.40" piston-rings, gudgeon pins, barrel studs and pushrods for a Model 19?Roy
Rob: Have you checked with…
Do you mind if they are sl…
Do you mind if they are slightly used and dirty? I am taking delivery of an assortment of used Norton parts. I will be keeping the twin parts (except for iron head) and getting rid of the singles parts. I saw maybe 5 or 6 pistons, all seemed to be 79mm. One iron barrel which I could not identify other than it had the cutaways for pushrod tubes.
Also a pair of single crankshafts which I don't need. The one I measured was for 100mm stroke, the other looked identical. Also a couple of dismantled laid down gearboxes. Everything was quite oily and well preserved. I didn't see any barrel studs though. Of course I prefer to swap for parts to complete my Atlas or 650SS. Next Spring the excess is all headed for a swap meet.
P.S. Also a rear mudguard and battery box (not featherbed) which someone on this list will help me identify.I should have taken pictures while I was there.
Rob:
Have you checked with Mike Pemberton at:
Pushrod Performance
www.pushrod-performance.co.uk
Phone: 01257 471014 Mobile: 07715 200706
Also: If you would give us a list of part numbers we could check with our local stockists
