Anybody recognise what bike these long roadholders are for? I cant find anywhere a brake plate that uses that single stop. Its driving me mad!
img_20160207_093739-jpg
Hmmmmmm. Are they in fact…
Hi Steve your forks are ci…
Hi Steve your forks are cica 1947/1948 long roadholders which would be fitted to to any of the road going models of that period however they have been modified with a different brake stop it should be a slot in the leg not a lump sticking out
Regards Roger
Hi Roger, hmm i don't thi…
Hi Roger, hmm i don't think so, the boss to which the brake stop is concentric is certainly part of the original forging. The nub of it is which model had a femaLe brake plate?
Hi Steve, This brake plate…
Hi Steve,
This brake plate anchor is the type used for the Manx conical hub brake plate. look at a few different photos and you should be able to see the detail. I am not sure if these are Manx forks or not as the standard casting has the bulge to provide thisanchorage simply by drilling and tapping the hole to suit the male fitting and removing the road-going type anchorage on the lower part of the leg. If this has been done there may be witness marks left, particularly where the grooved slothad been machined. I don't think Norton used forgedlegs on the Manxlong Road-holders, unlike the featherbed Manx. Hope this helps. Regards, Richard.
Sorry I dont have apic of…
Sorry I dont have apic of the iner side will post one tomorrow. Do youhave the "bulge "? see attached.
wp_20141012_004-jpg
Previously jonathan_newton…
My profile is identical to yours.
Hello again Jonathan,
So actually, the Manx Long Roadholder is a completely standard slider with a tapped hole and ground off lug and the standard slider has the "Bulge"?
Previously richard_cornish…
Previously richard_cornish wrote:
Hi Steve,
Hi Richard, So are you saying there were separate castings for the road bikes and Manx versions? ie all long roadholders of this vintage have the bulge but Manx ones were made without the lower anchorage? It seems odd, you would think the factory would just drill a hole and grind of the anchorage... Attached is a close up...
Regards, Steve
Previously steve_pickard w…
Hi Steve,
My apologies Richard, I confounded Jonathans photo as a continuation of your informative response. My reply to his post is actually for you.
Re-reading yours, I think you are saying that all long roadholders have the bulge but Manx ones were made without the lower anchorage?
Regards, Steve
Here isa rear viewIjustspottedon mydrive. Thelug sits justbelow the verticalfixingsforthemudgard support/ legbrace. Iam notsure of the vintageof mine as theyare part of theframethe rest of the1937Inter MSmachinewasbuiltinto after the war....
Do you needsome measurements?
Hi Steve,
Regards, Steve
Hi Jon, no picture was uploaded I'm afraid.
Hmmmmmm. Are they in fact a pair of modified fork legs made to fit a small brake on a trials bike perhaps?
