G15CS oil tank cover
The parts manual specifies 2 metal washers and 2 fibre washers for mounting the oil tank cover to the tank.
Can anyone tell me how these washers are situated? Both on outside? One inside and one outside cover?
Thank you,
Ed
The G15CS, and the N15CS as well as all the other models in the G15series from 1963 onwards used the same heat shield cover. Two washers 000012 are fitted under the heat shield onto the oil tank. The heat shield is then screwed on with the two chrome screws and the fibre washers go under the screw heads. This keeps the heat shield away fro the oil tank so that cold air can access and pass over the out side of the oil tank and this is an add to cooling the oil tank.All the parts are shown in the parts books.
Thank you Anthony. That is what I needed to know.
