Hello all
There is a fair amount of variation in the dimensions of the downward-pointing cylinder head studs - part no. 067885 (NM24389) - available from suppliers.
Does anyone know the precise original dimensions and thread sizes?
As a start my understanding (may be incorrect) is as follows:
Diameter of stud 3/8"Length of stud 1&7/8"20tpi BSC thread for 9/16" of stud for cylinder head thread26tpi BSC thread for 5/8" of stud for cylinder head nutsUnthreaded middle section 11/16"
I possess studs with 4 different combinations of overall length and length of threaded and unthreaded sections. I'd like to know what are the definitive dimensions, what is best to use and does it matter?
I'm happy to be pointed at existing messages or guidance which I may have missed.
Thank youAndy
Hi Andrew ......I think yo…
Phil Thank you for respond…
Phil
Thank you for responding. BSC was my understanding of the thread type not a typo. 26tpi is more usually BSC at 3/8". 20tpi can be either BSC or BSF. The trouble with these standards is there are so many to choose from!
I'm not sure how easy it is with basic measuring tools and a pair of Specsavers-enhanced Mk1 eyeballs to tell the difference between BSC and BSF threads - the thread cut angle differing by just 5 degrees.
I needed to know as I'd like to ensure that I'm using the correct threaded stud and would like to check maybe using a die and then use a plug tap to ensure that the threads in the cylinder head reach in far enough for the stud used.
Hope this makes sense. Thanks again.
Andy
I've done a bit more digg…
I've done a bit more digging on this on Access Norton.
The thread looks to be definitely 20tpi BSF on the part of the stud which fits into the cylinder head, i.e. as per Phil Hannam's response. The other threaded part is 26tpi BSC (aka CEI).
This list helps as it lists the thread type and tpi for the 067870 nut for the rear stud (No.2 in tightening sequence) confirming 26tpi CEI (aka BSC). I know this is not definitive but it appears to be a reliable source.
So if that's sorted the thread types what about the threaded and unthreaded dimensions?
Andy
I thought I'd try adding…
I thought I'd try adding a photo to show the variability in cylinder head stud size. 067885 in order of decreasing overall length.
Studs A, B and D have all been purchased recently from reputable suppliers.C was removed by me from my 750 Commando's cylinder head (not using mole grips!). The differences are significant and can result in a range of 9-12 20tpi threads used in the cylinder head and a difference of 3/16" in thread available to the 26tpi cylinder head nuts.
Andy
image-2-jpg
My own 750 Commando is a 7…
My own 750 Commando is a 71 build but 72 registered bike. All my engine studs, bolts and nuts appear to similar to those on the Atlas model. So they are a mix of Cycle, BSF and Whit threads.
I have been reminded that early in 1971 the Norton factory went over to UNF threads for many of the engine fixings. But I don't think that the 750 Commando cylinder head studs changed their threads.
A bit disappointed with th…
A bit disappointed with the lack of responses about the cylinder head stud dimensions.
I guess it's a bit 'rivet counter' but the consequences of a badly specified and manufactured cylinder head stud are at least a leaky cylinder head joint (for compressed petrol/air and oil from the push rod tunnels).
On my Commando the stud at tightening position No. 7 had completely pulled the thread from the cylinder head. This is stud type 'C' in the photo above. Also there is the possibility of the cylinder head stud nuts (063192 at the front) 'bottoming out', i.e. running out of threads to tighten the joint, if the lower section of the stud is not threaded enough.
The existing studs are a bit 'chewed' so I ordered a new set. This started my 'line of enquiry' because I was concerned that the first set of studs I ordered might be made of stainless steel. So I ordered a 2nd set from a different supplier. These had different dimensions to the first set. A 3rd set were different again and all were different compared with the set of studs removed from the cylinder head!
I'm happy to continue with measuring and checking for the best fit. I've just got the repaired cylinder head back from BLR Engineering so will keep you posted.
Andy
Hi Andrew ......I think you have made a slight typo in your list.
My Data Files shows as follows......
06-7885
STUD
BSF
3/8"x20-26x1-7/8"
CYLINDER HEAD
The early Model 7 Iron Head, Alloy Dominator Head and Commando heads all use studs of a different length.
List below may be of some help?
Threaded Holes - Aluminium Heavy Twin Heads.
All threaded holesare Whitworth form (with 55 degree thread angle).
Dominator, Atlas & Commando - forthe 3 head/barrel studs - 3/8 BSF x 20tpi
Atlas - headsteady centre stud hole - 3/8 BSF x 20tpi
