If of interest for anyone who has trouble with worn or damaged footrest serration, attached a drawing which may help.
Cheers,
Hans from Chile.
insert-1-jpg
Previously Hans Eberlein w…
OK. The aim to post such a…
OK. The aim to post such a solution was to help anyone that can?t access to made it by machining.
In my case, I own an old lathe, making a special device first to make a serration for my M75 Panther, wich has 20 teeth. For the Norton, I made of the device only the plate, with 16 holes, equal to a 22.5? each.
Attached the device.
img_3598-jpg
Also attached the whole le…
Also attached the whole left and right support, ready to be welded, but will wait until completing the restoration, to get a proper angle of the footrests.
img_3600-jpg
Previously Hans Eberlein wrote:
In case you are doing this by machine, another dimension that would help is the angle peak to peak (or valley to valley) which is 22.5 degrees.
