Featherbed head races
The Atlas Understeers markedly ,its especially noticable if I switch from the 99 to the Atlas. The head bearings could be orriginal so I will renew them Are sealed taper roller bearings availiable and is it still thought to be a good mod?.I did the 99 rollers 25 years ago (unsealed) so they may get renewed as well although it steers perfectly and turns in well.
I tried unsealed taper rollers years ago. Suffice to say, they were replaced with normal cup and cone bearings soon after.
Hello Robert - I do find it's better to replace the cup and cone offerings that AMC fitted to the featherbeds. However I should say that a pair of taper rollers are not my preference riding about towns and twisty countryside lanes. They steer much heavier than say a pair of angular contact ball bearings. In my production racing bikes I opted for a crowded ball thrust ball bearing set in the top and bottom races. In my road bikes I find that a pair of good European made thrust races with a brass cage steer well and last forever. The taper rollers tend to be a millimetre thicker than the angular contact ball so the yokes sit lower or higher however you're fitting them. That gap would need attention on a road bike. Cheers, Howard
You could try the Commando frame bearings as these fit ok and I have them in all my featherbed framed bikes.
Thanks Guys, Probably too much choice for my addled brain!.Looking at rgm's lists they don't appear to do featherbed std races but list commando ones and a conversion with a spacer?. Don't see any seals ,still use felts?.
