After about 10 years I finally have my 1951 ES2 up and running. Complete strip down and rebuilt myself. I took plenty of photos from many angles, but I do not have a photo of how the rear chainguard attaches to the frame near or at the plunger. Should be obvious I know, but I am missing something here. I have the parts list and illustrations for 1950, but my chain guard doesn't look exactly the same, similar but it has a stud welded pointed outwards near the plunger. Any help on how it attaches would be appreciated.
HI Justin, on my '51 rear…
Hi Paul, thanks for the re…
Hi Paul, thanks for the reply, unfortunatley I don't have the tube, the only fixing I have appears to be a screw with its head tacked onthe inside of the chain guardwith the thread protruding out towards the plunger. I will have to take a look at my photos again and see if that jogs my memory.
Justin
HI Justin, on my '51 rear chain guard, there is a tube welded across the top (at right angles),as depicted in the parts book item T23 (E4/497) This lines up with thepinch bolt hole in the frame where the springplungermain shaftis clamped. This longbolt (around 3 3/4"long),also secures the rear mud guard stays.
