Can't find them anywhere.Dominator 99 1960
Previously tony_booth wrot…
I have an old Dymo label p…
I have an old Dymo label printer, runs out a black plastic strip with the numbers, stick it on the headstock and it keeps the MOT man happy !.
Hello someone should of re…
Hello someone should of read my earlier threads then you know where to find frame number and Build date number, now we start again your build date number is on the top LUG Next to the HEAD Stock and your head steadybolts on to this the stamp markingsare on this top edge of this lug you need a craft knife to scrape off the paintwork to see it right has its in very small stamp markings the frame numberis stamp marked on the left hand gusset plate and should start with a 14 R and going down the gusset plate the frame number have fun yours anna j
hope you don't mind jumpe…
hope you don't mind jumped in with a photo of where the frame number should be i ground mine off before i took the photo you cant be to careful
Barry
doh!
it was a joke by the way
frame-number-jpg
OK, I assume it has been r…
OK, I assume it has been removed, seen this before. However, Norton had it stamped in another place. (Too many F/beds stolen to order to make blasted TR*t*n's)
The police at the time would know where to look and so now I'll tell you: You may need a magnifying glass but you should find it, with the tank off on the top of the head steady lug off the head stock.
hello yes the top lug give…
hello yes the top lug give you your build date stamp mark in this way, D/4/54 this is whats on my 54 dommie and this is whats stamped on my 1960 Norton Manxman 650 M/12/60 that'sthe build date stamp mark ok have lots of fun yours anna j
Frame number on mine, Anna…
Frame number on mine, Anna.
PS: (OFF TOPIC) Brexit majority was over 1.2 million. The number you referred to was total votes cast for Brexit.
Sorry if anyone was offended putting that here. I just remembered.
Thanks everyone, magnificent response and I found them on the frame gusset by the brake pedal as suggested and well painted over. Couldn't actually decypher the 14R stamped horizontally but got a definate frame number. I'll also know where to find the rest when I start the winter work.I did search for frame numbers on the boards but without results.Thanks again.Tony.
The problem is that when y…
The problem is that when you want to re-register an old bike that has no modern Reg document you need a frame number for age-related dating. Without it you will lose the free road tax as it would be given a "new" date. The gusset plate location is often very faint after blasting and re-enamelling. I just happen to have the right sized stamps to freshen up the original marks!
Previously Neil Wyatt wrot…
what are you on with this is the date stamp mark on the top lug right next to the headstock, the Numbers I have given are for my Norton Manxman650twin M/12/60 the M is for Manxman12 is the month 60 the year it was built right. PS you may have to scatch of some paint to find it As its in small numbers
yours anna j
Previously lionel_yexley w…
Previously anna jeannette…
yours anna j
In Reply to Off Topic Voting Of Brexit the votes where 17.493 million votes for out of the EU and get our country back in our hand and our laws made by us, we're better off out and stand on our own and trade with the world with no custom unions or anything and take back our 200 miles of fishing grounds build our own ships, railway and cars and vans and build The famous Norton motorcycles that will be a world-beating machine now all say Amen yours Anna J
Can't find them anywhere. Dominator 99 1960Thanks everyone, magnificent response and I found them on the frame gusset by the brake pedal as suggested and well painted over. Couldn't actually decypher the 14R stamped horizontally but got a definate frame number. I'll also know where to find the rest when I start the winter work. I did search for frame numbers on the boards but without results. Thanks again. Tony.
Hello Tony To register your motorcycle you need proof of date of manufacture, what I have told you and everyone the Number on the Top lug is vital has proof, I have had to do the same thing with My Norton Manxman 650 has it was Registeredwrongly the Date of manufacture was the proof I needed for the DVLA the date was M/12/60. for 1961 so now I have a very early 1961 reg but Dvladid do a lotof debating over this until they got the photo, of the date stamp marks from the top lug, So your frame number On the Gusset does not prove the date of manufacture,
yours anna j
Hi Tony. The frame number on my 1960 Domie 99 is on the left hand side lower frame gusset plate more or less above the rear brake pedal pivot. I also had a job finding it as the previous owner had the frame powder coated and the number was only faintly visible when you shone a light across it, it was more like indentation than a stamped number.Keep looking I'm sure you'll find it. If you get stuck I'll post a photo of where the number is on my frameJohn
