Disc brake front wheel removal
With a AP lockheed caliper and RGM adaptor plate, removing the front wheel to repair a puncture is a painful process when it comes to taking away the disc caliper adaptor plate. The nuts are all obscured by the wheel, disc, plate, caliper etc. My plan is to helicoil the caliper (10mm) and dispense with the nuts. Can anybody see why this would not be a good idea?
Hi Dave, the pull out load of the steel bolts from the nuts will be higher than a tapped thread in the caliper casting. The nut and bolts clamping on the caliper lug bosses will make the weakest part the smallest section where the boss joins the casting.
If you tapped the casting the load would be across the smaller section of the boss either side of the tapped hole.
It would be a weaker fixing, I do not think I would want to risk it, it would take a stress enginer to work out if it was strong enough.
Hi Chris,
I see your point, the other thing I might do is make a plate to slip behind the caliper with the 10mm threads in it.
Hi Chris,
You could try a C spaner shape with a nut each end. Its not easy getting the wheels out of some bikes. Some of the older bikes had stands front (mudguard stay) and rear. I find its not to bad in the garrage with the bike lift, electric hoist, large blocks of wood and a jack. Not so easy on the side of the road.
A Thames Valley member has got "Slime" in his wheels and had it work with a puncture.I have been carrying a container of it and a co2 inflation kit. If it fails its call the AA.
I wonder if any one else has any experience of "Slime".
Sorry am I missing something here, Why do you believe it necessary to remove any part of the braking system to allow removal of the front wheel?
I have the same/similar set-up on my bike and took the front wheel to my local dealer recently for a new tyre. Didn't remove the brake adaptor plate/caliper for that.
Roger
Valid point Roger. I'm used to the calipers being in the way on twin disc rotaries but now you come to mention it, it is probably do-able. in which case, one less spanner and allen key in the tool kit for Rimini
I don't think slime is supposed to go in the wheels before you have a puncture. I used it in mid Wales on a puncture on my rotary but a piece of stanley knife blade had been flicked up by the front tyre and ended up inside the back tyre, couldn't see the damage but it was too much for slime.
I'm not an engineer, but it seems to me that a helicoil will not be as strong as a nut and bolt. If helicoiling the caliper was the better way, why didn't they make it like that in the first place?
I do agree, though, that it is awkward to remove the wheel with a setup as you describe. My bike is a Mk3 with RGM caliper bracket and Grimeca caliper, so physically similar.
When I need to remove the wheel, I put 2" thick blocks of wood under the centre stand feet, and the wheel will then drop straight out as soon as the spindle is removed.
Maybe not too practical at the roadside........
Is the problem worth the time effort and worry about if the modified parts are up to the job? Better to find a suitable spanner to hold the nut and I use a pair of long nose pliers to get nut into place an hold it as you thread bolt in by turning that with your other hand.
How many times do you take the front or rear wheels out at the side of the road or in the comfort of your own home/garage/shed ? A friend of mine is paranoid about punctures an has had one 15 years ago amd one in the late 1970s. Tyres and tubes are hopefully improved over the years and in many thousands of miles I touch wood have had none on bikes and only one in a car.
The biggest problem is normally undoing the wheel spindle of a bike without a large tool which is most likely to be to bulky to fit in the bikes tool box. So if the worst ever did happen you will need a spanner or such that is at home or be calling for help from a friend or recovery service anyway.
I try to work on the ability to deal with a problem as quickly as possible so as to be able to continue on my way. To be stuck on the side of the road in France, Switzerland or Italy for the want of an innertube and end up waiting for rescue would be tedious. Judging by some of the posts on this forum, many owners would be incapable of removing their wheel, be it front or rear, at the side of the road. Three tyre levers and a small modern cycle pump and you're on your way. None of my friends with modern bikes can take their own wheels out. They wouldn't know where to start and when I offer to change a tyre for them and save them some money they take the view, "I'd rather take it to a garage" Proper tyre lube is an easy way to take the pain out of tyre changing and modern tyres, even for our old Nortons are much softer than they used to be and easier to fit.
