Cush Drive Rubbers question
Hi all -
Putting order together - have parts list/ manual but not clear on drawings - do I need 3 thick and 3 thin rubbers for rear wheel ?
1972 manufacture Combat Roadster. If both thick and thin needed for each socket , I presume the thick one is to be positioned to take up the load under acceleration ?
On a different subject, Group 13 - engine mountings , etc. - the two nuts / washers for the shaft that passes through the rear Isolastic to chassis mount are shown but not numbered . Would these be the same as on front Isolastic?
Thanks in advance for any help .
Richard
Yes you need 3 thin & 3 thick rubbers for cush drive, fitted as you say.
The nuts and washers are the same front & rear on the isolastics. Half inch UNF Nyloc nut.
Ian
Thanks Ian for the quick response !
