Belt Drive for Dominator
Is there a belt drive available that fits a 1959 Dominator 99 and uses the Dominator clutch, thus retaining the cush drive feature ? If so, would the belt tension be adjustable in the normal way by moving the gearbox ?
Hi Mike - All Dommie clutches need oil to lubricate the roller bearing between the clutch drum and the clutch centre. Oil is not a favourite of most belts. Some however will work satisfactorily in oil. Try Bob Newby , Tony Haywood, Norvil, Andover Norton etc. Most belt drive conversions use a Commando or modified Suzuki clutch. Once set the belts don't usually require resetting but initial setting up is so important. Good Luck, Howard
Hello, the Bob Newby six spring clutch its the best of the lot, it will cost you but you get your moneys worth, yours anna j
i agree with anna.the bob newby belt is hard to beat.i have three norton and use that system.the first one i bought seven years ago.
tony..
tony..
Tony,
The bike I have just bought has a belt drive fitted. I am merely trying to find out what make it is and all about it, before I go doing anything silly. Just hoping it's a Bob Newby !
Thanks, Mike
tony..
Tony,
Thanks, Mike
mike.
you never said you already had a belt drive fitted.you asked about belt drives ?.ask the right questions and you may get the right answer.A photo would help[ then members can tell what system youalready have] ...
tony..
Tony,
Thanks, Mike
mike.
Tony, I feel suitably chastised ! You are correct, I asked the wrong question. I guess my reason for this was in order to elicit opinions on the belt drive route that were not just comments on what I already have. However, I will try again with a photograph.
