1962 ES2 HT coil
I need to know where the HT coil is mounted on a 62 ES2 slimline, any help would be appreciated,
Thanking You
Sandy:
On my '61 model 50 the HT coil is mounted underneath the tool tray.
Your '62 ES2 should be the same.
On the twins the coil was clamped in a steel circular strap that was bolted to a frame tag under the front of the tool tray just behind the carb. Can't see any reason for the single to be different.
Hi Sandy
This subject came up in August 2014 in a post entitled 'featherbed single coil mounting' by Niall Topping.
I managed to post a picture of my slimline model 50 mount and I suppose they are the same................have a look
Regards John O
