1959 Roadholder forks
Hi, I am just rebuilding the forks on my 1959 Model 59 and putting them together there seems to be a space of about 1" between the top of the damper rod and the bottom of the fork stanchiontop nut. Is this normal? If not have I done something wrong? Will it cause any problems if I put a spacer in to fill the gap?
Thanks Jak
Normally you would block up the front wheel (bike on center stand) and screw the top of the rods into the chrome top nuts.
