Hi.Could anyone recommend someone to rebuild my gearbox please (north England). It's fully working, but I'm in the middle of a full restoration and would like to get the bearings/bushes replaced.
Alternatively, anyone willing to give me the encouragement & confidence to try myself?!?
Not that difficult.....
Gearbox rebuild.
Hi Andy,
Just give it a go, they are fairly straight forward. When you strip it, make sure to take photos at each stage of the strip-down and look to see how much wear there is as you remove each component.
The biggest improvement you can make will be to replace the "pain in the a**e" close ratio gears and fit a standard set from an ES2/16H etc. This will make the bike much more usable, not just in built-up areas, but all-round. As an example with the close set, the difference between 3rd and top gears is about 5mph in top speed so you have, in effect, a 3 speed gearbox. If you poodle along at 3,000 revs in 2nd gear you will be breaking the 30mph speed limit. Best to clean them up and put them in a nice box and impress your friends with your spare set of close gears.
.....with the exception of replacing the bushes for the shift mechanism in the side and then possibly honing to fit. So long as you have a heat source to R&R the bearings and understand sorting the mainshaft end float, it ain't rocket science. You might need the assistance of a service with a press. Give it a go.
