Is there an oil seal on the drive side main bearing, 1959 ES2.?
Is it available?
Many thanks Mikael, does it…
Many thanks Mikael, does it fit inside the crankcase and outside the bearings
Thanks again, this could be…
Thanks again, this could be an expensive rebuild, I thought i could just get away with a separate thin oil seal
Oil seal definite answer.
The definitive answer is :YES. There is a conventional rubber/steel backed oil seal fitted to the drive side crankcase.
The problem is the crankcase needs to be removed to replace the oil seal as it's fitted from inside the drive side crankcase. Not the most convenient of designs.
The seal is listed, but not illustrated, in the Spare Parts List for 1959 Models 88, 99, ES2 and 50. It is Publication PS 206.
The part number is 22474 and is listed just above the Connecting rod details as shown in the attached photo.
I had trouble sourcing one here in Oz for my 1961 ES2 but can give you the dimensions as I have a spare.
Sorry
Ian correct, never worked on a late one. Available at https://www.rgmnorton.co.uk/buy/single-cylinder-crankshaft-drive-side-oil-seal_3865.htm
Absolutely fantastic Ian, …
Absolutely fantastic Ian, [and Mikael]
I was coming to the conclusion that the crankcases need to be split, so that is a job for next week.
It is great to have a site like this where ES2 owners can get their heads together.
I will let you all know how I progress
Mainshaft ball bearing #17704. Picture on RGM website shows seal on one side.
