Can anyone tell me how a side-stand should be attached to the frame of my 1961 Navigator De-luxe? Does it bolt on a frame lug? Mine has a main-stand but no side-stand.
The bike is currently buried in my shed and very difficult to get at, so I am being a touch lazy here!
Umm - you’re not after the…
With no side stands at NOC …
With no side stands at NOC members have used other makes but did not mention which model they came from I think this would be a big help Bryon
Optional extra
Apparently they weren't fitted as standard - they were an optional extra.
Lightweight side stand
Hi All,
These were not fitted as standard, as stated above.
They fitted OUTSIDE the frame, onto a longer stud than normal, at the point the downtube meets the lower frame rails. Personally, I do not like the design, and would worry aboyt the stud bending if undue pressure is put on it (like a child sitting on the bike, while parked).
Sad really, as the centre stand is hard work, unless you develop a knack for it...
And yes - the one on FleaBay is correct (eBay item number: 283968511651)
Side stand
Here is a couple of photos of the side stand on my Navigator. Would this be the genuine item? Looking at Andy's information the fitting on the frame looks to be Norton, what about the stand, it has two places to anchor the spring.
The spring is a bit feeble, wore diameter of 1.75mm, are new available?
Side stand sold for £85
The used side stand for a lightweight on ebay sold for £85 and I bet a number of us were interested.
Like Bryon, I should like to know if anyone has fitted a side stand from another Norton or other marque and if so how successful it was.
As I get older I am finding it harder to get my Jubilee onto the centre stand as it is such a rise. Good for removing the rear wheel but less friendly for parking the bike. I have to say the original side stands look a bit feeble.
I see that bolt-on side stands (that grip the frame tube) are available quite cheaply, under £20, and so are side stands for small engine Enfields. I am thinking of modifying one of those to fit.
Dennis
the best way
hello now it ike andy says he dose not like this design so make your own even better make a plate up to fit both bolt holes and you may need a spacer at one end and have the part the stand fits to welded in place to this plate bracket, in middle of both engine mount bolt holes so this take twice the weigh and more safe , yours anna j
I recall that the lightweight side stand assembly was always fairly pricey when our spares scheme had them made. Was around £135 right?
Probably plus postage and VAT.
Have just seen part 22611, Side stand assembly lightweight twins, listed at £150.00 on the Norvil web site.
Of course this will be new, but the price is not so far from those re-manufacured by NOC.
Not the answer to your original question Lionel, but worth an enquiry by others if your lightweight is becoming a struggle to get on the centre stand.
Hi Peter/all, I was the one…
Hi Peter/all, I was the one who “won” (now there’s a misnomer for you) the ebay sidestand. Delivered price just under £90. Apart from shot blasting then powder coating (I do both myself) it’s in excellent condition so I consider it good value for money when compared against the current pricing from NOC shop of £120 + vat (even if there was stock!) & £150 from Norvil, so £90 is about right for a used item In my book. As I’m into my advancing years it’s a struggle to move my 850 Yamaha (yeah I know - it’s not a Norton) around now, a usable sidestand for the Jubilee makes sense since I’ve discovered how “strange” it is to get it onto the centre stand!
Well done!
I was watching it and would have gone to £95 but I couldn't be bovvered in the end! With VAT those prices work out at £156 and £180 - but Norvil no longer list them - only the spring. Not a surprise that they aren't easily available as they weren't fitted as standard. See my posting about what Members would like to see in the way of spares.
Dimensions?
I have to say that I am still not sure how it precisely fits on the frame. Is there a lug or drilling or does it fit an an engine plate? Anna mentions "both bolt holes".
The sketches are fairly useful but the dimensions would be most useful. The leg length being the most important one so that other possibilities can be considered.
The spring is listed on Norvil's site as Part No. 22614 for £8.42 +VAT & Postage.
Hi Lionel, sometime over the…
Hi Lionel, sometime over the next day or two I’ll post some dimensions for you
Bruce
Well done Bruce...
Well done Bruce I think you got a bargain. However, still no replies about other types of side stand that can be used on a lightweight not withstanding Anna's comment. I wish I had the skills and facilities to make a stand but I do not so adapting one from another source is my best bet.
Dennis
Hi Lionel - photos attached…
Hi Lionel - photos attached with tape rule beside it, should give you an indication of sizes. Note - the bottom frame stud has to be longer (noc shop says 5”) than standard so swivel block can be mounted on it - one of the pictures shows that stud.
If I can help further just let me know while it’s still in original condition off the bike.
Bruce
I followed..
.. Anna's excellent advice (on this topic anyway) and used a Suzuki stand from ebay for around a tenner for my ES2. I had to make a mounting plate but that was easy enough.
That looks good.
Ian,
That looks good. The plates look to give a much better anchorage than the single bolt on the original lightweight stand.
You don't happen to know which model of Suzuki the stand came off?
Dennis
norton side stand
hello well you can see why andy dose not like this type of norton side stand witch is way over priced as cheap looking and bound to fail at any time with only one stud holding it Well Suzuki had the sense to make a good side stand and kawasaki comes up close as there side stands are very good or you go all out to fabricate your out ten time better than norton could ever do Well I do not have a side stand for my Navigator so one of my own design is on the cards good luck guys yours anna j
Dimensions - side stand
I have a drawing from life on an A4 sheet of paper. Email me your address & I will copy & send.
Great!
Many thanks for the pics Bruce. My idea would be to see if another maker's fitted - like the Suzuki apparently. Not important enough for me to waste sleep over though! I have to get its carb sorted first and some of the screw terminal wiring that the previous owner fitted to a new wiring harness Before all that I have to start and expedition into my shed where it's stored on a hydraulic lift!
Anna, I have a Kawasaki side…
Anna, I have a Kawasaki side stand on my pre featherbed ES2, almost a straight bolt on for £20! I haven’t looked at fitting on the Jubilee but it should be simple.
Dan
Actually...
.. mine may be Kawasaki - sorry for confusing anyone. I think the model had several Zs in its name....
Looking back it was off a Kawasaki ZX600 / ZZR600.
I asked earlier in this…
I asked earlier in this thread If my Navigator had a Norton rather some other make side stand. From the subsequent posts it seems I have.
Anyone know why the stand has two locations for anchoring the spring?
Also, is there an up-stop or does the footrest spacer act as the up-stop as it does on mine?
Sorry John I don’t know but…
Sorry John I don’t know but I expect Andy will - drop him a message.
This is my Kawasaki stand on my ES2 I’ll be fitting one to my Navigator.
Kawasaki stand
Ian (and Dan),
Thanks for the information on the Kawasaki stand.
Dennis
I bought a side stand off ebay,,,
I bought a Kawasaki ZX600 side stand off ebay for £16 including postage. It is a robust item and it looks like it will do the job on my Jubilee. The stand looks identical to the one in Dan's photo.
I need to make up a small triangular plate to bolt the stand to the frame and a packing piece for the front lower frame bolt behind the plate but that looks simple enough. The stand will be anchored to two frame/engine bolts so that should be strong enough.
Dennis
kawasakis
hello perhaps we should use the kawasaki engine in our Nortons as well As ones I seen have done 100,000 plus with out any bother early kawasaki twins were very good engines and right hand foot change as well they copied BSA but did a lot better job , so the japanese have shown us the way how to build good motorcycle the only thing is they never beat the featherbed frame has will take engines up to a v8 rover So now its a side stand project to come from my 350 navi witch is not that bad an engine but could do with improvements and would make a nice 800 four , liquid cooled fitted into a spine frame design of the featherbed and that could the near future norton if only TVR listens yours anna j
Another side-stand solution
Inspired by all the comments above I thought I'd add a side stand to the "lockdown renovation" of my 1961 Navigator.
(To Ian Soady's point ... yes, there's another Kawasaki leaning against a wall somewhere.)
The photo shows the main steps for a couple of hours work, once the bits had arrived from ebay.
For those who look closely at the photos I emphasise "renovation" rather than "restoration" because there are several non-standard bits including a pair of fairing panels I made from sheet alloy (tin snips and rubber mallet essential), non-standard handlebars and the non-standard front mudguard which Andy S has already spotted.
Thanks for the original inspiration for the stand. More fettling to do though so I'm off to the garage now to try and adjust the clutch so I don't need to develop a left forearm the size of Popeye's to operate it.
Tom McM
Very helpful.
Tom,
Very helpful.
I have not fitted my side stand yet (another resto on the bike lift at the moment) but when I do I will follow your example.
Dennis
Great stuff and helpful pics…
Great stuff and helpful pics,just bought a zzr stand off ebay for £15 to put on my Navigator. Barrie.
Hi Tom Nice work, That's…
Hi Tom
Nice work, That's exactly how I intend to fit mine, although I have toyed with the idea of welding on a bracket extension rather than a bolted one.
Dan
Finally fitted a side stand to my Jubilee.
Finally fitted the Kawasaki side stand to my Jubilee today and it went well. For about £20 it is a really good solution. I only had to use a frame stud in place of an engine stud to attach it plus a bracing plate.
Dan's photo of his ES2 above looks like my fitment.
The bike sits well on the side stand and is well balanced. It looks like the stand is meant to be there.
I find the Jubilee is hard to get on to the centre stand so a side stand will come in useful.
Thank you for all the advice,
Dennis
Navi Side Stand Thanks!
Hey Tom!
A quick note to say thanks for this 'how to' for a Navigator side stand. I followed your instructions and it's gone well and not too costly! Good job!
Gez
Umm - you’re not after the same one on flea bay that I’m after are you (lol)?
Bruce
