Wideline brake pedal stop
I have been looking on Andover Norton's website on the 'featherbed twins' page, showing the frame and fittings:
https://andover-norton.co.uk/en/shop-drawing/890/wideline-featherbed-frame
There was discussion recently of the pedal stop fitted to slimline models. On the Wideline models, there is supposed to be an extended-head bolt mounted on a special stud.  These are items 72 and 74 on this page.  No. 74 turns out to be the tabbed washer used on slimlines, and is not the correct part. Does anyone have a picture of this part, a drawing, or know where it can be obtained?
I think this is it: .061954SS
Norvil have them, £15.50 + vat, for pre 1956.
Can you tell me where it bolts on the bike, exactly?  I suspect it mounts somewhere on the left swing arm gusset.
With those double nuts, it appears to be designed to be adjustable to centre on the brake pedal.
Never had one with that on, but if I remember correctly,  it bolts to a hole in the pillion footrest bracket at about 11 o'clock  to the footrest hole.
