To fuse or not to fuse - that is the question
I know fuses have been discussed elsewhere but this is a slightly different query. I have a new 6V Yuasa 6N6-1B battery complete with a fitted fuse. On inspection it transpires to be a 15A 240V "wire in glass" unit.So two queries: Surely that equate to 90W current? And secondly do I need it at all? The manual states "in order to simplify the system no fuse is provided." (Haycroft for a '55 ES2).Any help appreciated.
Slight confusion here George. A 15A fuse is safe to a 15 amp current. Wattage is a unit of power. Most fuses have a continuous rating (say 15 amps) and anrating at which they blow (say 25 amps). Fuses in a bike circuit are there to protect the battery in case of a short circuit. I would definitely have a fuse in the circuit. Having a battery short to earth is not a good thing... Have you ever seen what happens if you drop a spanner across two battery terminals? Don't try it at home.
Of course it is Gordon. My mistake. Not thinking!Just wondered why Norton didn't fit one to start with. I also confused myself with AC and DC. And I'm supposed to be an engineer - well, mechanical!
Aaahh! That takes me back! Still doesn't answer though why Norton didn't fit one. BTW - thanks Barry. Good info.
Norton probably didn't fit a fuse as the average ride to work rider would have blown it every time that he changed a bulb and been too hard up to buy a new one.
I cant think of any good reason not to fit a fuse and if you have an electronic regulator then it's pretty much essential. Even without, it could save you from a fire.
If the reg is electronic then the manufacturer may well have a recommendation. I have a 16a in-line.
