I know fuses have been discussed elsewhere but this is a slightly different query. I have a new 6V Yuasa 6N6-1B battery complete with a fitted fuse. On inspection it transpires to be a 15A 240V "wire in glass" unit.So two queries: Surely that equate to 90W current? And secondly do I need it at all? The manual states "in order to simplify the system no fuse is provided." (Haycroft for a '55 ES2).Any help appreciated.
George. hope this can help…
Slight confusion here Geor…
Slight confusion here George. A 15A fuse is safe to a 15 amp current. Wattage is a unit of power. Most fuses have a continuous rating (say 15 amps) and anrating at which they blow (say 25 amps). Fuses in a bike circuit are there to protect the battery in case of a short circuit. I would definitely have a fuse in the circuit. Having a battery short to earth is not a good thing... Have you ever seen what happens if you drop a spanner across two battery terminals? Don't try it at home.
Of course it is Gordon. My…
Of course it is Gordon. My mistake. Not thinking!Just wondered why Norton didn't fit one to start with. I also confused myself with AC and DC. And I'm supposed to be an engineer - well, mechanical!
Just remember watts = amps…
Just remember watts = amps X volts Or amps = watts/volts!
Aaahh! That takes me back!…
Aaahh! That takes me back! Still doesn't answer though why Norton didn't fit one. BTW - thanks Barry. Good info.
Norton probably didn't fi…
Norton probably didn't fit a fuse as the average ride to work rider would have blown it every time that he changed a bulb and been too hard up to buy a new one.
I cant think of any good reason not to fit a fuse and if you have an electronic regulator then it's pretty much essential. Even without, it could save you from a fire.
If the reg is electronic then the manufacturer may well have a recommendation. I have a 16a in-line.
George. hope this can help in some way to calculate fuses ect. i would put a fuse in. as close to the battery terminal as poss.
http://www.rapidtables.com/calc/electric/watt-volt-amp-calculator.htm
