Bit of help/advice please. I've started the resto on my 1962 Jubilee. The handlebars are one piece/moulded lever mounts(see attached word doc). Are these the correct bars for the bike? Secondly I'm struggling to find any info on the bars or spares for the rubber mounts that go under the four cup washers. I'm assuming these are AMC parts of some type? Any info and help would be greatly appreciated. Thanks in advance. Gary.
The origin..
Jubilee Bars
Hello Gary
Take a look at this thread https://www.nortonownersclub.org/node/10106
and post from Andy Sochanik.
I can remember the one piece moulding of the lugs fitting to the top fork yoke but couldn't recall the moulded levers - but my Jubilee ownership was 40 years ago!
Andy
My Jubilee has the same handlebars
My '64 Jubilee has the same handlebars. I did not know that there were rubber washers under the cup washers and I have not missed them!
I did get my handlebars re-chromed, not cheap but worth it as the bars are quite sturdy.
I bought new levers as the old ones were very slack in the bars. I think I bought some stainless lever pins/bolts from NOC shop and took out the slack on the pivot with shim washers - works fine and stops the levers rattling up and down.
Dennis
I might try a tap washer...
I might try an old type tap washer under the handlebar cup washers next time I take off the handlebars.
I used them for the tank rear mounting bolt and they work fine. If the washer is held firmly it is easy to use a sharp drill to enlarge the hole to the required diameter. Putting them in boiling water for a few minutes will soften them enough to take up the cup washer profile.
Dennis
Thanks Dennis(and others) I…
Thanks Dennis(and others) I'm taking the bars for re-chroming tomorrow - as you say I'm not expecting it to be cheap! The tap washer and boiling water is a good shout thanks. I've done a bit of internet trawling for Franny Barnett spares but no joy so far.
If you find the chroming too…
If you find the chroming too “eye watering” I’ve got a set in reasonable condition available, chrome not too bad - no pitting & clean/shiny. Depends on level you want from your re-build!
Bruce
Thank you Bruce, I'm going…
Thank you Bruce, I'm going to the chrome platers tomorrow am and I'll find out what its going to cost me to get the original bars re-chromed. This is my first forum post so I'm not up to speed with the etiquette, how much do want for them? I'll see if there is a contact facility.
Gary
If you “click” on my name it…
If you “click” on my name it’ll come up with a contact - that should get to me so we can talk about costs
I've done that Bruce so you…
I've done that Bruce so you should have a message...somewhere!!! Does it come through to your personal email? I can't see a PM function on the drop down lists.
Gary
Got your message via email &…
Got your message via email & just responded.
Bruce
The origin of the Jubilee was Francis Barnett, so perhaps a troll in their spares supply might help?
