Jubilee low compression
Afternoon all,
I’ve just refitted the heads on my rebuilt jubilee engine and I’m only getting about 35psi compression on each cylinder. Stripped & cleaned all parts, honed bores & fitted new std pistons & rings as bores showed very little wear.
I haven’t yet refitted the idler timing gear and there are clearances under all the tappets.
Any ideas where I should start looking first?
Many thanks
Kieren
Similar thread on the singles section M50 compression.
Most answers will be similar - WOT, crank speed, temperature  etc,etc.
Fwiw, 35psi is very low and sounds like a closed throttle figure.
George.
Thanks George,
Your closed throttle comments have enabled me to realise what an idiot I’m being -
no timing idler = inlet valves closed = low compression!!
Dunce hat please!
According to the engine data sheet I have, attached it’s a compression ratio of 8.75:1 which works out to be about 128psi.
once I get a chance to assemble the timing gears properly and then check my compression I’ll update the thread with the results!
Kieren
Managed to get 125psi on both cylinders finally, but needed to put some eng oil into the bore, dry pressures stayed very low, approx 50-80psi.
Hi Kieran, I would expect the hot engine figure will be close to your oiled figure. Important bit is that they are similar on each cylinder. Personally I would worry about other things on the bike now rather than compression until it has bedded in/run a bit.
Regards, George.
Yep, considering it’s only an engine on the bench at the moment - definitely!
now to prep the frame & forks for painting & rebuild....plus the fact that my priority is to replace the headlight on my main ride - melted it with the heat gun trying to split it to upgrade the projectors (2011 Triumph Tiger)
whoops!
Kieren:
Your engine is way too clean!!!   No staining at all.
What did you use to get it that way?
Hi Mike,
It’s a restoration job, engine hasn’t run in 40yrs so I stripped it and had a local guy vapour clean it.
it’s not run yet that’s why there’s no staining!!
