2015 Norton 961 Sport Drain Plug
Looking for a oil drain plug replacement need new one.... original is getting stripped very soft material any suggestions
new Norton owner
This is where I got mine from
Burnett & Hillman: Hydraulic Adaptors fittings & components
'Burnett & Hillman  Hydraulic supplies'  just look on the web.
Your looking for ....'Metric socket head with 3869 seal'. If you type in 'Metric socket head' in the search box it should take you straight to the correct page. Just make sure you order the right size and pitch thread
Peter thanks as a newbie I’m not sure the size of the drain plug I have a sizes m10 to m27 to choose from is the correct size in the manual
Michael:
Have you checked with your local dealer for the replacement plug?
It would seem to me to be the place to go to.
Michael:
If you can give me the part number I will check the local sources here in the San Francisco Bay Area.
