Looking for a oil drain plug replacement need new one.... original is getting stripped very soft material any suggestions
new Norton owner
Drain plug size? Is it in the manual
Peter thanks as a newbie I’m not sure the size of the drain plug I have a sizes m10 to m27 to choose from is the correct size in the manual
Local dealer for supply?
Michael:
Have you checked with your local dealer for the replacement plug?
It would seem to me to be the place to go to.
Dealer closed in Seattle Wa USA
My local dealer went under :( no longer around
Part number???
Michael:
If you can give me the part number I will check the local sources here in the San Francisco Bay Area.
This is where I got mine from
Burnett & Hillman: Hydraulic Adaptors fittings & components
'Burnett & Hillman Hydraulic supplies' just look on the web.
Your looking for ....'Metric socket head with 3869 seal'. If you type in 'Metric socket head' in the search box it should take you straight to the correct page. Just make sure you order the right size and pitch thread
