Monobloc choke slide not fully up
Monobloc 376 choke slide is not fully going up still a bit about 5mm still showing is this normal
thank
Not normal, it should fully retract.  I would be checking the cable length.  I've removed my choke slide, cable and lever etc and fitted a blanking plug to the top of the carb and just use the tickler to get it started as it never needed much choke anyway.
If i pull the cable fully up at the carb it still shows a bit i know i have it correctly assembled the brass tube fully seated in carb top wonder if there were variations on the length of this tube?
Had same problem with a Monobloc. 10 mm down. Took the easy route and did as Bob and removed it. Tickle and starts okay. No idle before it had warmed up a bit. Otherwise no problem.
.. that the tube is off a 389? I seem to remember that I had a similar problem and just trimmed the tube by 1/4" or so. I have a big box full of Amal parts so am never quite sure what originated where.
In reply to by ian_soady
You could well be right thanks theyhave different part numbers don’t suppose anyone here knows what the length is for a 376?
thanks
Took some measurements and trimmed 5mm from brass tube after making sure the choke slide couldn’t disengage from the main slide and jam it. Don’t suppose it will make a measurable difference but good to know it’s fully up
