Model 7 tank mounts
my frame has had the petrol tank mounts removed, I can remake and fit but do not have any dimensions to go on. Please could you have a look if you have a frame available to take the width, outside diameter and inside diameter of each of the two tubular fittings, many thanks in advance. Andy
Andy,
I've attached a drawing of the front mounting bracket that I've measured on my frame.  The rear bracket is not so easily accessible, but will try and measure it tomorrow for you.  I hope you don't mind the measurements in millimetres.
Did you mean to post this query on the Singles forum?  I only ask this because if you have a single cylinder machine then the petrol tank mountings are totally different.
Philip
Philip
thank you so much for doing this, Andy
