Hi All,
I am rebuilding a 1930 model 18 motor for a friend and wanted to confirm what the valve timing specifications are.
I have a book called Motor Cycling maintenance series Norton motorcycles 1928-55.
In the data section it says Model 18 1928-1931 compression ratio-6.0-1
Valve timing- Inlet opens 1/4" BTDC
Exhaust closes 1/4" ATDC
Ignition Timing 1/2" BTDC Fully Advanced
Tappet Clearance Cold Inlet/Outlet 0.003
Can anybody confirm that this is correct.
Andy
Singles - Engine Data
Andy, My 1930 Norton…
Andy,
My 1930 Norton Maintenance manual lists the following data:
Exhaust opens 0.75" (or 55-60 degrees BBDC).
Exhaust closes 0.25" (or 25-30 degrees ATDC).
Inlet opens 0.25" (or 25-30 degrees BTDC).
Inlet closes 0.4375" (or 40-45 degrees ABDC).
Tappet clearance is 0.003" for both inlet and exhaust valves.
Agree with Andy as above but…
Agree with Andy as above but mine was really hard to start so l set ignition timing at 5/16 BTDC. With a bit of choke now and a few purgr kicks after a flooded carb with lifter in she starts first time...trial and error each one is slightly different
I agree with Ian. Why not…
I agree with Ian. Why not set it to 5/8 and also mark the lever at 5/16. Too far retarded and it will be sluggish and hot.
Thanks everybody for your…
Thanks everybody for your replies, I will try the 5/8" for the timing and go from there.
Andy
Hi Andrew.......the attachment if from the E.M. Franks Maintenance Book for Nortons - circa 1932 onwards. The info may be of help.
