Hi
I am correcting a bodged up bike for a friend.
Can someone let me know the dimensions of the following.
Rear wheel spacer outside of brake drum (goes over dummy axle) and the cotton reel one for the right side between the frame and wheel.
The 2 front wheel spacer nuts that are inside and outside of the brake plate.
Thanks guys
Best I can do.
That's a good start
Thanks Richard,
It looks like I have the inner nut for the front brake plate, so I will make the outer based on your picture.
I just need the rear spacer dimensions.......when you get a minute:-)
My left rear seems to be 5/8…
My left rear seems to be 5/8", and right is 3/4". But those are measured on the bike so not very accurate. And who knows if they are the same way round as when it was first assembled 80 years ago?
I don't have a set apart to measure, but this photo on .5cm squares might help if no-one comes up with anything better.
