kickstart return spring
I urgently need the kickstart return spring for the laydown gear box for my 1956 Dominator 99. The spring that I received from Andover Norton is incorrect and RGM currently do not have one in stock.
 I have been advised that the correct original  part number is A2 / 367. Any ideas as to where I  can obtain the correct spring from ?
Thanks in anticipation, George
p.s. Just been advised that Norvil have them in stock !
I did try to get into the NOC shop but for some reason I kept getting the message that the server was down. I tried several times. I would have preferred  to support the NOC but just my bad luck I  I guess. Not only that but the items are cheaper too.
George
