All,
Is it worth maintaining the balance pipes on my Mk2A resto / project?
Is there any benefit to having the balance pipe, over just two separate pipes?
Reason I ask is that the down pipes I have (with balance pipes) are rusty and I need to replace, but do I need the added complication and parts of the balance pipe?
Thanks - Paul.
BHP & availability
It helps mid range torque…
It helps mid range torque but only slightly, unconfirmed by dyno just by seat of the pants. My set of balanced pipes are too rusty to use but have kept them as they never split so maybe one of these days I can get copies made in stainless. I use unbalanced for now.
Colin, John, Thanks for…
Colin, John,
Thanks for the tips.
If I cant get new balanced - then I guess that somewhat restricts my options.
Thanks - Paul.
Hard to fit
I always found the balanced pipes a real pain to get to fit with the pipes tucked in nicely on my 850. I much preferred the single pipes with conical seats and peashooters.
I understand from another member of this forum that a balance pipe boosts BHP slightly. Also, if you find a source of balanced exhausts for a MK2A, do share! I believe that the MK3 pipes are different, and, the last time I checked, the MK2A pipes were unavailable. There was a rumour that AN were working on a set …
