Dommi top end disaster !
Bike is a 1959 Dommi '99'. I bought this in the summer as a fully rebuilt working machine. When attempting to adjust the tappets I couldn't get the valve clearances adjusted correctly so I bought a new set of tappets. In trying to fit these it became apparent that the locking nut on the tappet would not fit above the rocker arm as it should. The tappet had to be wound so far through the rocker arm that there was no thread left for the lock nut. So, I fitted the locknut on the underside of the rocker arm. This troubled me. Why should this be necessary ? I decided to investigate so I've removed the head and barrel. This is what I've found:
All four push rods knackered. The top end of each is mutilated with bits of torn aluminium all over the place.
All four cam follower cups damaged, two beyond re using, although it may be prudent to renew all four.
Circlip missing from gudgeon pin on one piston. The gudgeon pin has slid into the bore and created a massive groove in what appears to be a liner.
One piston (already +.040") damaged beyond repair.
The barrel has a piece of it's casting broken off at the base of the damaged bore. As this piece is not in the engine the barrel must have been installed in this state during the rebuild !
I'm now facing new liners, new pistons, new rings and new cam followers. I'm hopeful that all bits, especially the main piece of the dislodged circlip, have not and will not find their way into any bearings or gears within the crankcase. I've flushed it out to the best of my ability.
My Questions:
1. What type of failure causes this type of damage to pushrods and cam followers ?
2. Can I ignore the damage to the barrel casting and solve the problem with liners and new standard pistons ?
3. I am assuming damage to the bore is just due to the circlip either not being inserted properly or in it breaking ? More understandable than the push rod damage.
3. Is it safe to assume the missing piece of circlip has somehow been blown out through the exhaust system, or is it necessary to split the crankcase and search ?
4. Where  is the best place to go for the replacement parts ?
Mike Haworth
That sounds awful. Did you buy it from a dealer, in which case you may have a case against them?
I would strip the engine completely as it sounds as though it's been assembled by an idiot so even if the circlip isn't in the crankcase waiting to create mayhem there may be other horrors is there. And anyway you'd always be waiting for the other hammer to drop.
I had a comprehensive seizure on a Commando years ago (oil pipe blew off the filter) and the bent / broken con rod took a chunk out of the base of the cylinder casting. I stoned off the remaining sharp edge and it was fine afterwards. Although as the bike was stolen a few years later I can't speak for the long term.
That sounds like a lot of anguish. Sorry to hear of your predicament and I am sure that you will receive plenty of help from the forum. To try and answer your points:
1. It would appear that wrong pushrods may be part of the problem. If they were too short (as would necessitate the adjusters being as you describe) the geometry would be out, resulting in loading of the pushrod ends at a greater angle to the vertical than designed. The initial failure mechanism here will have caused wear debris from here to have dropped to the cam followers and initiated damage there that then self perpetuated.
2. Without seeing the damage to the casting of the barrels, it is difficult to say if this is a problem or not. If it is in a low stress area then new liners and pistons etc may be in order
3. I concur. It is very easy to neglect to check that the circlip is not properly seated if you are unaware of the possibility. The question is where has the wear debris from the barrel liner got too? The circlip must have gone into the crankcase if the rings are not broken (assuming it was there in the first place) so the worst case possibility is that it may have got into the main bearings or if broken enough, to the oil pump.
Personally, I would suggest that a complete strip is necessary to check that there is no follow on damage or excess wear from all of the debris that has been floating around. Initial thoughts are that the camshaft lobes may also have suffered - as may the oil pump, mains, big end s etc or that you may have been lucky. Only a full strip will tell.
As to where to get the parts. First get yourself a parts manual for your bike so that you can order the correct parts. All of the usual suppliers. (RGM, Andover Norton and Norvil) hold good parts coverage.
Hello Mike - are your pushrods the all alloy after-market copies ? If not are they straight alloy rods with cast iron ends or are they the later hollow-blown alloy tubes with cast iron ends ?  The later are mostly used in 650's but can cause trouble in 99 cylinders.  No one would insert a gudgeon pin into a piston without the circlip so it must have gone upwards or downwards.  If it went up it may have passed through an exhaust valve throat and exited down the pipe  If it went downwards then it, or its remains, are still in there - sadly.  New 600 liners are available from RGM and you will be well advised to try and get new pistons.  New followers and pushrods are also available.       Good luck, Howard
Mike, I feel your pain! The engine was obviously built by Barney Rubble.
You can't not re-build the whole engine now.. No point in spending good money on the top end and chancing the bottom.
Probably best to take the barrels to whoever would press in new liners, and ask if the casting will take the trauma of the new fittings. They might not guarantee it? New barrels might be an option?
 I think that all that metal would have shown up vividly at the last oil change (or the first?). Both in the oil and on the magnetic? sump plug.
Being cynical, it sounds like Barney Rubble thought it would be a good time to punt it on pretty quickly. I would definitely be on the sellers case very heavily. Take plenty of pictures and even get an expert witness if possible. You could well have a case even if you bought the bike "As seen". Do you have a copy of the original advert description ?
Morning Mike , i am sorry to hear about your disaster, you may remember contacting me with regard to my rebuilt dommie for sale. Now you have all these problems you have no real option but to do as i did which is a complete rebuild from top to bottom, as the top is such a disaster you now have no idea what shape the bottom end is in. If i can be of any help please contact me as i have some good spares that i changed on my rebuild. You can contact me on 07502906055
Regards  Ivor
Oh dear. I too bought one like that once. In my case, blasting media had not been properly flushed out of the crankcase when the PO rebuilt the engine.The oil did that job once the engine was run, destroying everything. I bought it from a West Country dealer, who didn't want to know, and I didn't have the will to take him to court.
Best advice when changing a camshaft is that the followers should be changed too. Thus the reverse is also true, hence the need for a full engine strip. It is the only way that you will have peace of mind. It will be expensive.
Ian
No, not from a dealer. The guy I bought it from knew little of it's history. I have been in contact with the guy he bought it from but, again, he didn't rebuild it. On the face of it it's a beautiful bike. The paintwork is immaculate. It is 12v with Boyer ignition. It has a belt drive modification. If you look around there has been amazing attention given to detail throughout the renovation. It just doesn't ring true that someone ploughing this much money into a machine would skimp on the engine ! I'm wondering if something has gone wrong since the rebuild and it was then fixed just enough to get it running.
I gather from another reply that, if I replace the cam followers as seems to be essential given the damage, that I will need to replace the camshaft ! If this is the case then I have no option but to split the crankcase. As the camshaft seems to be in excellent condition I definitely hadn't forseen the need for such a costly replacement. I haven't even looked at what a new camshaft will cost !
Ivor, Thanks for your offer of help. I'm still considering my course of action. From most of the replies it seems a full rebuild is required. As I'm being advised that if new followers are fitted then so should a new camshaft be, it would appear I have no option but to split the crankcase. As something of a novice at this it looks to be a daunting task - and expensive ! Foolishly it seems, paying loads of money for a bike does not guarantee you get a good bike.
Regards,
Dominators with std camshafts rarely have trouble with them and I'm not sure the followers are damaged from your description. Mine are still all perfect at nearly 60 years old. A light stoning is all that it usually needed. Don't mix them up.You may be looking at the rocker ends?.A std second hand cam is cheap, £20. If needed. Don't need an SS cam . Give us some photo's. There is a load of rockers on E-bay right now ,some may be for a later head. Give us some photos of the bike too.May stop the guesswork. If it helps I have bought restored bikes that looked beautifull but had stupid mechanical work done. I have a brand new Hemmings 2s cam you can buy for £130  if you want, I doubt you need it though.
Mike - I have used new cam followers on a used camshaft in the past and all worked well.  If your bike has a decent camshaft and it hasn't been damaged by anything coming down the follower turrets then I'm confident that it will be OK.  Those all alloy pushrods are a nuisance as they damage very quickly but it is likely that they were the incorrect length in the first place.  When the valve stem lengths increased in the mid sixties the pushrod lengths decreased to keep a similar geometry.  If you combine that with the different lengths for 500,600,650,750 and 850 it is understandable that after-market companies got confused - so they produced dross but still sold them.  You should try and read the number off the face of your valves and then match up your new followers and pushrods to suit.  Wet and dry paper should clean the deposits from the valves enough to read the numbers.  Your followers are probably radiussed but if they used later pushrods then they may have used flat followers.   Cheers for now, Howard
Hello Mike while you have a major rebuild on your hands please take the time to check the rocker spindle inner bushes in the head for ovality as they are prone to wear. All of mine were 1 mm oval and had to be machined and re bushed, i also modified my new spindles and end plates so that it is impossible for them to rotate in the future. ( Photo's atached )If you remember when we spoke i mentioned how much my rebuild cost as it was a no expence spared rebuild,but there is only one way to do a job like this and if its right it is expensive. Also if you have the alloy head check the push rod tunnels as sometimes when they changed from steel to alloy push rods they were inclined to rub the inside of the tunnels in which case the push rod tunnels will need to be machined to give a greater clearance.
Mike do not contemplate not stripping the engine as a lot of that metal will have gone into the oil pump and all the other components also remember to clean the sludge trap.If you send me your e'mail i will send you some photo's of my rebuild.
    Regards Ivor
"It just doesn't ring true that someone ploughing this much money into a machine would skimp on the engine ! "
Sadly, from my own experience, this rings all too true in these days of 'classic' bikes (and cars) being regarded by many as icons whose only real purpose is to be displayed as an ego trip by the (often fairly well-heeled) owner and for the envious, nostalgic reminiscences of those who view them.
I've personally fallen for this sort of thing on at least three occasions (maybe I'm a slow learner or, as I prefer to think, hope springs eternal, and paying a fairly high price for an immaculately-presented 'fully restored' machine from an apparently trustworthy vendor should provide what it says on the tin - a fully restored machine).
In my own case, a Velocette Venom, an Ariel Leader and at least two Nortons, all of which required immediate mechanical surgery and, in the case of the otherwise immaculate Venom, a full engine rebuild was needed (also, the reason that the speedo wasn't working, I found, was because the speedo drive was just a highly-polished empty shell with no drive gears!)
According to Murphy's law (though he was an optimist), it seems a total strip is needed.
Thinking of the about 25 used bikes I've bought, 8 had only minor faults. 32% chance to aquire a decent bike. Among the good ones are a 99, a Goldie, a 16H, a Comet and a Venom.
You mentioned at the start that all 4 cam follower cups are damaged, 2 beyond repair. It is always recommended that camshaft and followers are changed together. Certain suppliers will guarantee neither unless that is done. However if the faces of the camshaft are perfect, then you could get away with it, but with no guarantee..
The point really is that the engine needs stripping fully to be sure of finding out everything. At that point you can take a view on the camshaft. If in doubt, I would recommend changing it.
I'm probably being a bit dense ,but can't imagine the damage you are seeing .,the cup on the top of the follower does very little work and even if indented could be cleaned up with a spare pushrod and a bit of fine grinding paste ,it does not need to be perfect as it does little. PHOTO please.
Hello Sorry to hear your trouble   sound to me like the engine has been built from different year of engine parts  by some one not having  much clue and Norton Twin , there engine part from different  years will not fit each other as earlier parts are that bit smaller in size they start to grow just that bit at a time over the years of production   so someone has fit an number of wrong parts and these have not received the correct lubrication   and inadequate   cearense,s  thus an engine failure the cylinder head shown in photo is from a later machine  , if you do your research on the period parts you may find what you may need and from now on you need to remove the engine and do a complete strip and start again with the correct parts  looking on ebay or NOC shop  you may find the right parts for your rebuild   you need standard parts its not a race bike the camshaft will be a QR cam casting number T2219 O2  stamp marked QR  the NOC shop as some than need resurfacing with a set of followers radiused  sent off to RGM Motors that do these jobs at a good price,   witch i have a spare set in good nick  witch will not brake the piggy bank you have two or three months to do your rebuild so no sweet take you time and follow a good hand manual  and work clean at all times and take photos in every stage,   yours   anna j
Anna if you bother to read the posts correctly you will see that the two photo's are not of Mikes cyilnder head  but belong to my dommie during my rebuild posted as a reff point for mike to check whilst rebuilding his own engine. The correct camshaft for the 600 dommie is 06 7817 which is the same as the early commando. The problems Mike has now could well be caused by someone buying second hand parts off Ebay
     Regards Ivor
Some years ago (don't ask how many!) I had a pushrod top wear down and cause grief. Reason the top cup wore down (solid alloy rods) was a rocker shaft had turned and this blocked the oil supply to the rockers.
The drive was the same. Commando cam has Different lift ,timing and running clearances. Needs different pushrods and valve springs,different barrel clearances.Different life expectancy.lots of aged 7's 77's 88 and 99's still happily running orriginal parts. Lots of Commandos with new cams.
Robert I,m not going to keep bouncing this about but the camshaft on the very early commando is the same as the 600 dommie 99.When Norton changed the cam in 1970 to what was known as the interim model camshaft part number 06 1084 the push rods and valve  springs were different but that was due to barrel changes. I have checked the Norton parts list and checked with Norton tech dept today and the camshaft for early commando and 600 dommie are the same. You cannot have a camshaft with different profiles with the same part number.
I agree with nearly  everything you say. and its  quite possible that the current  makers think the parts are exactly the same and therefore simply interchangeable But they are not. You could likely run an early Commando or Atlas with a 56 Dommy cam and have no bother apart from a reduced performance and some extra clatter Put an Atlas or early Commando cam in the Dommy and you need to change other parts and increase the  clearance in several places. So how can the old and new parts be the same?. Many times have I ordered Dommy parts and been sent Commando bits that don't fit or need modifying.It is just how it is.
The following info is taken from the unreleased Dominator Service Notes...........
There were four main camshafts produced by the Norton Factory for their standard Dominator engined bikes. All have the casting number of T2219. Those for the Model 7 engine are best avoided if the plan is to rebuild a post 1956 engine and expect a decent road performance from it. The first camshaft was right for the early ‘Iron headed’ engine, in that it helped to produce enough power without the top half over-cooking.
The later ‘Aluminium cylinder heads were able to cope with more power; especially those with the extended finning. So when the 99 engine arrived, with the ‘Daytona’ camshaft in 1956, this had extended times for valve openings, increasing the power, but also the valve train noise. The addition of a 0.010' ramp to its lobes, around 1959, to help quieten down the engine rattles. Hence the title of Q.R. camshaft. These identification letters generally being stamped onto its sidewall.
 The fourth variation of the camshaft arrived with the Downdraft SS cylinder heads. (But was also fitted to the non-downdraft head used on the 99SS).
Basically it was the QR camshaft but slightly altered in profile and renamed as the SS. Most have a casting number of T2219@3. From 1960, this camshaft was a standard fitting for all the Dominator SS engines, including Atlas and Mercury. It even survived, in a modified form, to become a standard Commando part until ousted, for a while, by the arrival of the Combat 2S disaster.
The earliest SS camshafts were stamped with X1 (Bracebridge) or X2 (mostly from Woolwich). The X2 camshafts were supposed to have deeper hardening to cope with the 650 engines power but the late John Hudson claimed that the X1 version was produced with greater accuracy. Later Mercury camshafts often just have the casting number.
The SS camshaft will fit into any of the pre-1960 engines and run quite happily as long as excessive revs are avoided. Otherwise valve float can occur, especially above 6000rpm. But who (track day lads excepted) hammers an engine that much nowadays?
The attachment shows the four Dominator camshafts used in production bikes from 1949 up to 1969. The camshaft on the far right came from a very early Dunstall tuned 99. His later versions having the option of a fitted needle-roller bearing and positive oil feed.
Thank you Phill. It seems possible that the bikes current problems stem from fitting perhaps 88  push rods in a 99. If  a new cam and pushrods to suit are purchased  its also possible that the barrel will need releving and the 99 clearances of 3and 5 thou be increased .
hello I have to disagree  the cast marks are T2219 @2  QR  and Norton part number 21225  later camshaft cast number T2210 x2  for ATLAS  1963  as I am looking at it,  and also have a QR cam as spare   and for 650  Norton part number 22729 .cast number T2219 x1  cam followers  Norton part number 22772 rh and 22771lh  push rod  Norton part number 99std m14/82in and m14/82ex all  part numbers are from a original Norton Parts book for 1959 season  and a 1961 parts book as cross reference     your anna j  dixon
The followers rod seatings are indeed well hammered from careless assembly work.In the old days of no cash I would have buzzed off any crumbly bits and lapped the seating with some fine paste and a spare rod. They would most likely worked fine as long as the rods were properly seated on assembly. I'm a bit more fussy these days and would happily lightly stone some SH followers and use with the milder QR cam (also cleaned up if needed). The mild  cam with oil bath on these 88/99 engines gives the  parts an easier time than on many later engines.The Hemmings cam (which you don't need) is a   Commando  profile cam made to fit a Dommy .
And the remaining thickness of the bottom barrel spigots outside the sleeves (which have already been fitted) is so small it can hardly do anything anyway. So I'd resleeve. I agree with Robert. What you do about damaged top edges of the followers is up to you. The edges don't carry much of the loads so are not all that important when running but they do retain oil and do help hold the rods in place on reassembly. New ones will look nice but will they really work better?
Can you see the condition of the cam shaft?  And the important bottom faces of the followers? It does look like wrong push rod lengths. There are lots of lengths and I doubt if going by the book will help a lot. Maybe use the wrecked old ones to help measure? Did the tips of the rocker adjusters touch the rocker covers? If the adjusters were wound out as far as you say them they must have done so.
Good luck.
The shoulders round the follower rod seats also help retain the rods in the advent of valve float,the odd missed gear can happen when you are chasing that Fireblade!.
I will look at some cam followers tomorrow if there is enough meat below the damaged pushrod seat, I can machine them deeper using a set of imperial sized domed milling cutters and also mill off the damage to give the hole the correct depth, if it works you will need custom length pushrods made up. Would be a shame to throw away the stellite that has worked with the camshaft and not showing any wear.
I think 99 inlets are the longest Norton rods,could possibly rework those for new exhaust ones,and just get longer made up for the inlets. Another thought ,If the wrong springs fitted would that have allowed lots of valve float and damage?.
Hello Robert and Mike - I did once fit SS valve springs in a Dommie head because I had an SS cam fitted and lo and behold I did get a lot of wear on the pushrod ends where the rocker engages.  Dommie springs are longer but weaker than the SS variety.  Also the SS cam with the flat followers opens and closes the valve gear much quicker and slamming the pushrod into the rocker will produce wear on an all alloy pushrod.  I'm not so sure about the wear on the cup on the follower.  Is it possible that the cast iron will wear as much as the alloy ? Did you decide yet what type of camshaft is fitted Mike ?  Lots to beware when rebuilding starts........Cheers, Howard
I've read on this site about all-alloy pushrods, and now I've seen photos of damaged ones.  Are these common?  Mine are alloy tubes with steel end caps.  Surely much superior?  I assumed they are standard because when I bought one some years ago, it also had the steel caps.
Hello John,
                  This may be an option but how do I get pushrods made ? I wouldn't know what length to specify or where to go to get the work done. Given the numerous and diverse responses to my original posting, clearly by some very competent engineers, I'm beginning to wonder if I have the ability to rebuild this engine to an acceptable standard. My normal approach would be to specify my bike to someone like Andover or RGM and say "sell me some pushrods to fit that bike". I'm beginning to suspect that this approach won't work. There seems to be so many different push rods out there, varying by length and material ! Now you are saying have some made. I went to a meeting of Bournemouth NOC members on Wednesdayand I came away struggling to get a definitive answer from the varied opinions on the pushrod issue.
You could try a dial gauge with the rod down the tappet holes. Check the lift against 'dyno dave's Atlantic green' web site says. You won't get an accurate profile but should get the lift. Don't despair. For push rods you could start with what you have and work out how much shorter you need.
Nortons  have two series of engines,  twin chain ending with the 20M3, and single chain starting with 20M3S.
I show the primary series of production TC cams minus the "daytona". First two are 3" radius lifters and the 22729 is flat lifter.
NHT twin chain cams
This profile is better/more accurate than the one on my website. It will replace the one currently there.
Hello again Mike -  If you look at the image of camshafts included in Phil Hannam's text you will see that along the camshaft just inside the bush in the timing chest there are raised up casting numbers (T2219 etc) and often as you rotate the shaft you will see extra stampings in that section that were stamped on before the hardening process.  Most of the cams have the same casting numbers.  A late Dommie 88 or 99 may have QR stamped on, indicating that it's a Daytona type profile with Quietening Ramps - hence the code. When the SS came out in 1961 the stamping changed to X1 and later on it became X2.  So have a good butchers and look for QR, X1 or X2.    If these are not present then there are other alternatives (pre-Daytona and post-SS) but please have a look first.  Your Model will have had QR type from new.  In the re-build  all sorts could have been adopted but generally unless it was built for racing, sprinting or some such use an SS or Daytona is best.   Cheers, Howard
If you decide to fit new  or secondhand  followers  ,then you can buy a set of standard 99 pushrods  with no problems, Worth checking that the rocker ends that engage with the pushrods are not damaged by the mahem that has been going on.The likelyhood is that you will have a Daytona QR cam and flat base followers would suit. But anything is possible over the life of the bike.
It only took a few seconds out in the shop to check my 10 TC cams. They have...T2219(SA)1, T2219(SA)2, T2219(SA)3, or cast core w/no marking, or aftermarket fully machined blanks.
However in my cams the SS cams are only on the latest core blanks T2219(SA)3 or cast core w/no marking,.  The  measured 22729 SS cam have X1, X2, or NO hardness marking, and Lift is what identifies the cam not a hardness marking.
Unfortunately , here in the US I have had no access to components like the daytona cam. Since the Daytona cam precedes the QR, I would avoid it in preference to the QR. Everyone seems to be saying the daytona and QR are almost the same?
IMO For a 99 a SS grind may be a bit severe considering the 99 reputation. However they are almost nonexistant here and just getting enough parts here to get one running is almost a miracle.
If my research proves correct the barrels need to be SS machined to work with the SS cam, the lifters would be flat, later push rods  and the valve springs need to be the later style.
Some discussion here on SS barrels
https://www.accessnorton.com/NortonCommando/dommy-ss-barrels.24545/
Not sure if your 1959-99 has the components to build a 99SS without a lot of updates to your components.
My 1959 88 was the origin of my QR cam and had radiused lifters. I believe I am the first to take this bottom end apart...
The QR cam  is the Daytona grind with added ramps and was fitted to my 1960  99**  (built late59 ) and my  61 88  . Both had flat followers. Seems possible that the radiused  followers  were phased out around 59 in the uk .I will do some checking .Interesting that the graph shows the cam timings to be the same for the QR and later cam.  Thats not what the books say.
My 88 engine is 814XX with the QR stamped cam and radius lifters. This motor sat unmolested for decades and seemed to only have cylinder and top end work done to it. I have been looking to profile a daytona cam just for curiosity sake. The difference may well be minor but I'm sure my rig will measure the difference. The Mitutoyo dial indicator I used was a "new in the box" given to me because it was ordered wrong and was an odd ball that indicates/measures to .0001". The brass shoe in the rig can be interchanged with flat or 3" radius.
cam fixture
The SS cam had an 8 degree lead inlet opening over exhaust closing ,The Daytona QR has only 2 degrees.  according to the blurb. John Hudson (who built some fast motors)  was very particular about maintaining that lead. The only practical way of doing that is to play with the tappet clearances I think.
