I have recently become aware of a novel (to me at least) way to assure that copper head gaskets do
not leak oil. It involves use of a soft .005 copper wire around the push rod tunnels and the oil return
hole where the thin wire is crossed over itself and Pliobond sealant is used.
There is a useful video detailing this method, see: https://jsmotorsport.com/js-motorsport-videos/ . Scroll down to select the "Norton Head Building Video". It's an interesting video overall but the part using the copper head gasket with the .005 wire is about 3/4 of the way into the video.
Has anyone tried this method and if so please report your experience ?
My '74 Commando Mk 2a continues to leak oil, i.e. the infamous "3rd fin problem". I have made improvements but it still isn't good enough.
Most recent attempt was with an original Andover Norton gasket using WellSeal. Helped but didn't completely solve the oil leak problem. I have resorted to wearing inexpensive plastic MC boots to spare my better boots.
Attached is a MSWord File "Ron_Norton_Cu_Head_Gasket.docx" with info on the source of the company who posts the videos.
Ron Wellman
Midland Michigan, USA
Norton Copper Head Gasket
Interesting....
That he didn't mention annealing the copper gasket before fitting which in my experience is the key. A well annealed gasket together with wellseal around the pushrod tunnels gave me a leak-free head joint on my 850 Commando.
I've never heard of the triangular machining of studs and can't really see the point.
A good point, Ian. I…
A good point, Ian. I annealed the gasket when I fitted it, but didn't put any Wellseal on. Will try that next time.
Apparently, the machining is supposed to allow the studs to stretch and hold the head tighter. ?? Won't be trying that one though!
Kevin
Yes, annealing too.
Ian,
I have and will re-anneal my copper head gasket. Yes it was an over site on the video author's part as I presume he assumed anyone using a copper gasket would know to do that.
I'm not buying the triangular studs either -- too expensive.
Ron
stagg wellseal
Hello do you lot mean Stagg wellseal you can get in 500g tins as well as 100g tubes I been using this stuff for years they did a red stagg wellseal pipe joint compound too well have fun yours anna j
Wellseal Not Easily Found In The USA
Anna,
Available lots of places in the UK but for whatever reason NOT here in the USA.
Royal Mail could not ship it to me in the USA.
Ron
Try a composite gasket.
Personally I think the composite head gaskets are much better than the solid copper ones. They work fine with nothing applied but could put a bit of sealant around the pushrod tunnels if you wanted to.
Ian
My Last Attempt Was A Composit Gasket With Wellseal
Ian,
I did use Wellseal with a Andover Norton composite gasket, helped but not enough.
Ron
I've tried using thin copper…
I've tried using thin copper wire on my early ('Pioneer') veteran. I won't know until the end of March if it gets from Epsom to Brighton without blowing rasberries as I go. But it proved to be difficult in practice to make sure the wire loop stayed in the right place. Ideally I think it should go inside a groove, but I don't see how that would work either. I don't want a sealant in case I can't get it off.
Wellseal never "sets"
.. so I've never found any difficulty in separating joints I've used it on.
You can also use Silk thread…
You can also use Silk thread coated with a sealant applied between finger and thumb as an alternative.
I never got on with the composite
Much preferred a well annealed copper version.
I'm always amazed that people fit new copper washers without annealing them as well - although I'm increasingly using Dowty washers these days.
Thanks for that link Ron, looks like I may be needing it quite soon :-(
Kevin
