Wiring diagram
Help,
Can anyone supply,share or point me in the right direction to a simple wiring diagram for my Jubilee I want to keep it as simple as possible and use toggle switches for the lights and ignition and a solid state rectifier.
Cheers Dave.
I have a simple circuit diagram for my Electra that uses a Boyer Power Box, this may give you a good starting point.
http://www.nortonownersclub.org/noc-chat/technical3-light-twins-forum/291192408/296355758/Electra-Circuit-Iss-2.pdf
It is not that easy to use simple toggle switches as the rear light has to be able to come on with both the side and head lights. Also if you are intending to keep it with 6V electrics and only a rectifier and not a proper regulation system then you will need to do something to switch in the extra coils when the headlights are on.
Hi Tony,
Thanks for your reply,seems like most simple ideas its not as easy as it sounds.I was going to have the lights on all the time (the same as my volvo) would this make a difference! Thanks again for the diagram.
Cheers Dave.
