Just starting to restore the frame and tin wear can any one advise on the measurements and thickness of the metal triangular bracket at holds the fuel tank in place, or if any one has a spare one or can tell me if the are available to purchase. noc spares do not hold this part. any help would be appreciated trevor
Previously peter_holland1…
Previously peter_holland1 wrote:
Hello Trevor,
You have my phone number on the inside front page of Roadholder. I have the part you need and probably a lot more.
Live near Skipton. Maybe you are just down the road? Give me a ring if you are still stuck.
Peter Holland
Hi peter
sorry for the delay in responding , I have resolved the problem of the fuel tank bracket the issue I have now is the rear number plate which appears to be a single hole at the top and two at the bottom just like the ones fitted to my triumph t90 or even a cub do you have a picture of the correct one I assume this is a standard amc part??
regards
Trevor
Previously trevor_veale wr…
Hello Trevor,
Hi peter
regards
Trevor
Hi Peter
my location is as far south as you can get before catching the ferry to the IOW I am in Southampton
Hello Trevor,
Peter Holland
