Jubilee piston clearance
Can anyone tell me what the recommended clearance is for a Jubilee piston, mine is waiting for a rebore.
I should add that they are heptolite pistons and came with no instuctions.
Dan
Hi Dan,
I don't know the correct clearance. I have had three different Jubilee engines rebored - all years ago-and each time I just supplied barrels and pistons to the engineering shop and left it to their superior knowledge. Any experienced machinist knows to allow more clearance on old aircooled British bikes,
So far I have had no problems with this.
Patrick
My engineer is going to do what he normally does but I said I'd check what was specified knowing that the jubilee piston is prone to cracking,
Dan
Hi Dan,
Hi Dan,
When you get your engine up and running give good attention to the ignition timing. I was always told that over advanced ignition timing can be fatal to the Jubilee engine. In one respect at least the original points system is better than going electronic as you can time each cylinder independently.
Patrick.
