Solid state rectifier
Hi just got a 1961 jubilee project to keep my busy!! I have a problem with the rectifier, its a solid state type with four wires on it
the earth,red ,white and blue this does not match up to the new loom that came with the bike.Apart from the earth does it matter
how it is connected to the wires in the new loom.Any advice would very helpful,its over forty years since I last worked on a bike so I am on a steep learning curve.Thanks Dave.
Hi Dave,
Yes, it does matter, you should (very basically)have one wire to battery, one to earth & the other two from the alternator, I would imagine they would bethe white & blue, the red would usually suggest positive. Solid state rectifiers are polarity & voltagesensitive so make sure it matches the polarity & voltageof your bike. My best advice would be talk to Al Oz, the clubs electrical guru, (AO Services, 01953 884681) If you can give him some details he may know what you have & what colour does what, worst case he sells new rectifiers at a very reasonable cost.
Regards, Tim
Hi Tim
Thanks for the advice,i will give AO services a try.I thought putting in the loom would be the easy part!! On another note I am really impressed with the spec of the jubilee(maybe a little on the heavy side) but they seem to have gained a poor reputation,any thoughts on this.
Cheers, Dave
Hi Dave,
I haven't had too much to do with Jubilee's, but bought a Navigator (basically the same but with a bit more power)for the wife about four years ago & have been mighty impressed with it. It was pulled from a shed where it had sat for many years, I did basic recomissioning work & she's used it trouble free ever since. She says it's more comfortable, betterballanced,& handles better than her Virago ! I don't know why they gained the poor reputation in their day, as I know of many Jubilee's, Navigators & the odd Electra that are used fairly regularly nowadays without major issues, infact I'd go so far as to say they're often more reliable than some of their larger siblings. That'll put the cat amongst the pidgeons :) Anyway, stick with it, get it sorted & enjoy it, they realy are good fun on slower roads.
All the best, Tim
Hi Dave,
All the best, Tim
Hi Tim,
I think I will paint that slogan on the garage wall (stick with it,get it sorted & enjoy it),wonder if it translates in to Latin!!
Cheers,Tim
Previously tim_gostling wrote:
Hi Dave,
Regards, Tim
HI, you guys have got me interested as I am currently attempting to revive my old Navigator and suspect I have rectifier trouble, I am curious about the four wires on your rectifier as I have only got three, Brown, Green and White!! My problem appears to be that my rectifier appears to be going to earth and therefore no spark, Can you enlighten me as to the four wires, three wires please?
Hello there,
Did you realise that you are replying to a thread that is 4 years old. Anyway no problem. I believe that you are referring to the old type rectifier originally fitted to the Jubilee and Navigator - this had three terminals and earthed through it's fixing screw to the frame. Tim is referring to modern solid state rectifiers which are both cheaper and superior. These have four terminals.
The best advice is to throw away the old rectifier and fit a solid state replacement and to do what Tim says -i.e contact Al Osborne on Electrical as he genuinely does know his way around Lightweight Norton electrics.
Patrick
Previously david_moore1 wrote:
Hi Tim,
Cheers,Tim
Google translate:
persta digeraque tum oblecta te
Use at your own risk, of course.
