Navigator oil tank
Hi can anyone help me with the connections on the oil tank i have two pipes on the top and two on the right hand side the upper one on the side has a'T' piece rats have chewed through the pipes and i am unsure which goesto where many thanks.
Hi Paul, Ithink the top 2 are breathers, one connects to the crankcase breather and the other one is just a vent.Dont think it matters which is which.
The 2 on the bottom are the main feed to the oil pump and the return. The one at the bottom right hand side(with the filter screwed into the tank)is the feed and it connects to the right handpipe on the sump, as veiwed when sitting on the bike. The other upperone with the tee is the return which connects onto the other pipe on the sump to the lefthand side of the feed. The tee off this one goes to another tee to the cylinderheads.
Thanks for your help in this matter thanks again Paul
Thanks for getting back, No tee, so that's why I can make it work,
onlyone return. I see a tank on eBay, with a small pipe coming off at
bottom. So that's what I need, so if anybody knows were I can get
one , will be many thanks.
