As mentioned in the other thread " Planning to buy a Navigator"the planning phase is now over and the bike is in my workshop.
According to the papers the bike was put off the road in 2004.
Initally the barrels and heads were missing but I bought some barrels in the UK and also some NOS heads are on the way from London.
The previous owner made a new wiring harness but with only two colours: red and blue- the first thing to throw out. He also changed the electric system to 12 volts and installed a Boyer ingnition. There is a Wipac rotor in the parts pile and a Lucas stator from a Commando, which does not quite fit onto the studs in the primary case. I also have a 6 Volt stator. Will have to find out how this goes together.
I already repositioned the rear fender which was mounted in a rather odd angle.
The gearbox mainshaft has a lot of play on the drive sprocket side, I guess the bearing is toast. What size do I need? It is the early type gearbox.
Attachments IMG_20160805_163534886%20-449x800.jpg IMG_20160807_165305354%20-800x449.Today I wanted to fit the…
Today I wanted to fit the powdercoated centre stand without success!
Somehow the tube has shrunk!
Maybe 150? Celsius at powdercoating was too much for it!
It is now too short to conncet the stand legs.
Also the holes in the stand legs for it are not parallel with the holes for the pivot stud. Therefore the tube, rather a rod, has this slight curve.
I will get a piece of 15mm tube and make a new connecting rod out of it or use my newly aquired centre stand.
I looked at the photos before dismantling and there it looked okay.
Disturbing!
Thank you Peter Holland for the elaborate explanation of the differences between the stand springs.
Hi Ulrich, Sounds mysterio…
Hi Ulrich,
Sounds mysterious. If the stand fitted before it should fit again. Looking at your picture of the centre stand the inner spacer is not in the picture. (There are two outer spacers and one inner spacer). Are you fitting the outer spacers the wrong way round ? They seem much thicker than my recollection of them. All my bikes are now in Winter quarters so I can't easily have a look.
Patrick.
Patrick, the inner spacer…
Patrick, the inner spacer is welded to the rear frame channel in my case. The two outer spacers are also "homemade" from some PO.The holes in the legs are enlarged compared to the holes in the centre stand I recently bought. The spacers I have do not fit into the "original" stand. The spacers go inside between the frame channel and the stand legs, right?
As you said it fitted before. I made some pics before taking apart the frame but unfortunatly they did not show clearly the fitting of the stand.
Well, I?ll sort this out soon.
The left frame loop is at the powdercoaters. They take off the coating with some acid and put on new coating with the frame number masked off. Hopefully I get it on Wednesday. The number starts with 17... which points to a Jubilee frame part. This number is also written in the papers. I also have a copy of the Belgian papers with this number. A Navigator frame number starts with 19.. The powdercoaters masked off a number on the right frame loop which is 19062 or so. I did not notice this number before.
Attachments IMG_20161017_080451567%20-793x800.jpg IMG_20161017_081128582%20-800x595.Brilliant, now I know what…
Brilliant, now I know what the stand stop looks like, thanks Ulrich!
Ulrich, I completely agree…
Ulrich,
I completely agree with your fixing of the spacers- so it's a mystery why the stand doesn't fit. The spacers/bushes are very similar in design to the NOCshop modified items and should be superior to the standard Norton item as they help to stop the stand bending.
Is it possible that it's due to a build-up of the powder coating on the mating surfaces ,i.e the faces of the spacers/the channel section/the stand? The original parts had only a thin coat of cellulose paint and the mating faces of the spacers probably wasn't painted at all.
Yes you're right about the Jubilee(17) and Navigator(19) frame numbers. Will this cause you much problem with registration in Germany? The frame number on the right hand side could be 9062? 19.(missing a digit) In my limited experience the 17 or 19 comes after the number ON THE FRAME but oddly enough on all my UK REGISTRATION DOCUMENTS the 17 or 19 is at the start of the number. I don't know why this should be. The Club dating officer could be the best man to verify for you.
Patrick
The powdercoating is thick…
The powdercoating is thicker than the old paint but not that thick , about 2cm!
I have german regristation papers for the bike with the 17... number. Also a copy of the Belgian papers with the same number.
The bike was brought to Belgium in 1983. I am in contact with the Belgian owner. He rebuilt the engine an put in a modified pickup from a Commando. He wrote me:
ps make it rev ;I gave quite a few commandos on twisty roads a run for their money on it!
It is easier to get it back on the road with these papers. You just make a normal technical inspection at TÃV (MOT). When you have no papers it is more difficult and more expensive.
Centre stand problem solve…
Centre stand problem solved. I bought a 15mm tube at the local second hand metal dealer about 1.5meters for 1 Euro! I cut off the right lenght but again had to slightly bend it to make the pivot rod go through.
Attachments img_20161019_132305945-704x800-jpgNice easy fix ... result!!
Hi Ulrich, I don't want t…
Hi Ulrich,
I don't want to be a pessimist but I think you will still have a problem when you come to refit your frame side rails. The outside edge of the top of the stand seems to be out of line with the spacers where the footrest bar fits through. It might just be an optical illusion (I hope so) in the picture but it looks as if the stand is too wide at the top. You might have to file down the stand spacers to get the frame side rails to line up. I hope I'm wrong and I am sure you will succeed.
Patrick
Well, it was in there befo…
Well, it was in there before. I only have the right frame rail at the moment because the left one is still at the powdercoaters, will get it next week. I held it against the stand assembly an it looked ok.
This is the picture I took before dismantling the frame. A bit out of focus but you see things fit together (hopefully)...
Another question: There are two connections for hoses on top rear of the oil tank an a small extra one on the return pie. (chain oiler??)
Where do the hoses connect to?
Attachments IMG_20161016_163144343%20-800x417.jpg IMG_20161016_163150719%20-800x659.Your before picture is fin…
Your before picture is fine - so hopefully it all pulls together properly when you get your frame rails back.
The oil pipes are easy to sort; the small pipe on the return line-oil tank front- connects to the rockers ( approx 22 inches of 3/16 bore oil grade pipe needed), The pipe at the top rear of the oil tank connects to the engine breather (approx 24 inches of 1/4 bore oil grade pipe) and the other pipe connects to the rear chain guard ( approx 20 inches of 1/4 bore oil grade pipe.
These dimensions were given to me in 1994 by T Brock and Ray Sage of the NOC.
You might have some problem in getting these old imperial bore sizes now but the nearest metric should be fine.
Patrick.
Don't forget in the final…
Don't forget in the final build up to fit the mud flap at the bottom of the frame channel section. This is supposed to prevent dirt from the back wheel being thrown around the back of the engine.
The mud flap is held on by the same two bolts/nuts which hold the stand stop on. My Navigator De Luxe has what might be an original mud flap and it seems to be made of some sort of compressed fibre board. It looks very poor quality and I doubt if it's waterproof but it has lasted 55 years - best to make one out of plastic. It's only about 10cm wide x 9cm deep.
Your stand stop in your picture looks a home made item but it should do the job OK.
Patrick.
Aaah! It was a mudflap! I…
I looked at the pics from Ian Easton form his Electra rebuild and one showed pieces of cracked fibre board held by the stand stop.
I thought it was some kind of "shock absorber cushion" for the stand because Ian made a new one just as wide as the stand stop metal "arm". So did I.
Will fashion a new one with your given dimensions out of a rubber mat.
The stand stop is not homemade but purchased in the NOC shop. Also the stopping rubber!
It?s the real thing! Mine was missing.
Far more important is the fixing of the rear mudguard bracket to the centre channel BEFORE you fix the engine unless you have superflex fingers..
Almost the same when restoring a Commando- start with the horn! I guess this was the first part to be laid on the production line- then came the frame and so on..
Yes, I found out too that…
Yes, I found out too that it wasn't some kind of cushion behind the stop (which didn't make much sense anyway) but I copied what I had. Obviously it was the remnants of a mud flap. I didn't think of it as anything else because of the material it was made out of. I'll make one out of rubber for it now I know. I'm pleased to see in your photo where the round rubber bumper goes. I bought one and couldn't figure out where it went - now I know.
Hello Ian! Your pictures o…
Hello Ian!
Your pictures of your build are also a great help for me.
I also had the issue of too many holes in the rear mudguard. It looked like a swiss cheese! Mine is painted so I gave it away to weld the holes shut. I have to find the proper position for it and then drill holes for the side handles an upper mounts at the shocks. The PO had a extension fitted at the front of the guard (see my first post in this threat)so it was way too low at the back.I removed it, drilled some new holes but it was not sitting correctly also. Not sure if it is the original mudguard anyway.
Yours looks like to be a bit high in the rear, almost like a scrambler.
I was thinking it looks hi…
I was thinking it looks high too, especially if I compare it to the original adverts. If I move it to the front set of holes I have then the front bracket will miss by a few inches.
I got the pins in the ligh…
I got the pins in the light switch sorted and soldered the cables to it. I also have the switch socket for it and added the missing clamp.
The rear Hagon shocks now have shrouds as the original shocks.
And the mudflap at the bottom of the centre channel was made of some rubber mat.
Attachments IMG_20161024_082543104_HDR%20-644x800.jpg IMG_20161024_082608740%20-643xGetting there Ulrich!
You are doing a very thoro…
You are doing a very thorough job.
Previously patrick_mullen…
The oil pipes are easy to sort; ..... and the other pipe connects to the rear chain guard ( approx 20 inches of 1/4 bore oil grade pipe....
Where and how is this hose fixed to the chainguard?
I have no closed chaincase but only the upper chainguard.
On my Standard Navigator t…
On my Standard Navigator there is a hole with a rubber grommet in the top of the standard chainguard - about 15/20mm from the front edge. The breather pipe simply pushes into this hole and any oil mist from the breather lubricates the chain. My De Luxe Navigator with the fully enclosed chaincase is virtually identical.
Patrick
Interesting .... no hole o…
Interesting .... no hole on my chain guard that I can see?!
Hi Dan, I can't guarantee…
Hi Dan,
I can't guarantee that this is original Norton fitting as I have two other chainguards which don't have the hole in them. However the two chainguards without the holes are definitely not Norton originals while the fully enclosed chaincase on the De Luxe is almost certainly an original part. Also in the Norton Spare Parts List for 1959 under Rear Chainguard and Fittings there is a ' Breather pipe grommet' - part no 18285 - listed. The same grommet - same part no - fits both the standard and the Full Rear Chaincase (optional equipment).
It is a tidy method of fitting and very practical.
Patrick.
I'm not sure mine is orig…
I'm not sure mine is original, but it's certainly a bit battered! As you say it's a tidy way of dealing with the breather.
dan
No hole in my chainguard e…
No hole in my chainguard either.
Will find another way to fix the breather hose.
The previous owner used some sort of filter at the end of the hose.
Attachments img_6605-800x575-jpgHi Ulrich, My Navigator on…
Hi Ulrich,
My Navigator only puts out some oil when it wet sumps after it has been left unused for months. Then it can leave a puddle of oil as it runs out of the breather pipe unto the chain and on to the ground. The chrome filter is probably unnecessary but it looks good so your choice.
You said you only had the UPPER chainguard. The Standard type chainguard is actually three parts - an upper guard (part no 22341), a lower guard (part no 21161) and a chainguard extension (part no 23172). The NOC shop keeps them all I think.
As a matter of interest the original price in 1961 was ; eight shillings and six pence for the upper guard and the lower guard was four shillings. That's in old money so I think about 62.5 pence in modern. And there was no VAT to pay as well.
Patrick
The frame, wheels and susp…
The frame, wheels and suspension of the Francis Barnett range of larger two stroke motorcycles formed the starting point for the Norton lightweight. ( All part of AMC group) The chainguard of Francis Barnett cruiser was used for the Norton Lightweights, but an additional hole added for the oil tank breather.
The FB, being two stroke, didn't have an oil tank.
Sellers of pattern chainguards describe the part as suitable for FB or Norton Lightweight. But it doesn't have the Norton hole!
Today I finally got the le…
Today I finally got the left frame loop from the powdercoaters. So I could complete the frame built up.The number is now visible. Eventually I will cover it with some matching spray paint after the German MOT and paperwork is done.
The rear swing arm is also in place. The centre stand (it fits!)is held by a new chromed spring. I ordered it via Ebay. It is originally for a Peugeot scooter. The horn has also found it?s place with a selfmade bracket.
Also the oil lines to the engine are already in place
Attachments IMG_20161031_120020988%20-800x420.jpg IMG_20161031_143311948%20-800x467.You will feel happier now…
You will feel happier now that the frame fits properly back together. Your upper chainguard looks the correct shape to me. What Peter says makes complete sense that the replica chainguard is made to fit the Francis Barnett and simply by adding a hole it becomes a Norton chainguard. Easy.
Today?s task: fitting the…
Today?s task:
fitting the rear wheel. Firstly I drilled a hole into the front end of the chainguard to fix the breather hose from the oil tank. Then the rear wheel was slipped into the rear swing arm and the chain was laid on.
Gentlemen, please have a look at the picture with the brake pedal stop. I have no clue how it is fixed. It was missing and I ordered a new one from the NOC shop.
I fashioned a bracket for the stop light switch which has to be painted . I had to bend the brake rod or else it would interfere with the passenger footrest.
Attachments IMG_20161102_145911113.jpg IMG_20161102_155945380%20-800x449.jpg https:Hi Ulrich that is coming o…
Hi Ulrich that is coming on nicely,
I have had the same conundrums! .... But I think the brake light switch was mounted on a bracket from the back of the rear footrest mount, that's where mine is going, I also had to bend my brake rod, having spent a while straightening it! But I made mine into a bow shape. There is clear evidence of it rubbing for many years so this must be normal, your bend looks very professional!
The good news is you have the brake lever stop in the right place, although all the pictures I have show it being positioned vertically and directly under the footrest.
Hope that helps
dan
Thanks Dan for shedding a…
Thanks Dan for shedding a light on the brake pedal stop!
The brake light switch was mounted on the on the footrest mount but by a homemade bracket of the PO. I saw some pics on which it was mounted the way I did. Maybe I move it back to the footrest because the cables are a bit short.
The 1959 Maintenance Manua…
The 1959 Maintenance Manual says;
BRAKE PEDAL ADJUSTMENT.
The brake pedal stop is situated at the left hand end of the footrest rod. By slackening off the footrest rod nut the pedal stop may be rotated and locked into another position, thus providing a certain amount of adjustment. Altering the position of the pedal pad will necessitate adjustment of the brake rod.
The straight brake rod on mine rubs the passenger footrest. I think this is normal but it has been queried by the vehicle test examiner when the bike was tested. He did pass it as the rod does not rub when the bike is in the riding position, i.e the rod only rubs the footrest when on the stand. The Norton footrest is specially shaped at this point to allow maximum clearance.
Patrick.
Thank you Patrick for the…
Thank you Patrick for the explanation of the brake pedal stop adjustment.
Don?t know if the passenger footrest is original. I changed the mounting point of the stop light switch. It now is mounted at the footrest hanger. I made a new bracket for it which is bent at the bottom so it does not move around when tightening the footrest nut. I left a slight bend in the brake rod. But as you stated it won?t rub the footrest when riding the bike. The shocks are compressed and so the rear brake has another angle to the brake pedal.
I also started to make a new wiring harness, far more simple than the original one.
Now I wait for the delivery from the NOC shop order. Also parts have to be painted so there will not be much progress in the near future.
Attachments IMG_20161103_124954729_HDR%20-800x449.jpg IMG_20161103_165136308%20-800xTony, could?nt get much cl…
Tony, could?nt get much clearer. Thank you !
I bought a battery and con…
I bought a battery and connected the wiring harness.
Everything works so far!
Only the Wipac switch for the lights has a connection problem. I already ordered a new one. I made a positive ground connection point for all items ( lights, ignition, rear lights, headlamp) and moved the power box to the rear of the centre channnel for better cooling and to get it out of the way from the carburettor. Have to bundle and clean up the wiring a little bit.
Attachments img_20161109_154445348-449x800-jpg regulator%20power%20box.jpgThe NOC shop order arrived…
The NOC shop order arrived on Friday. Pistons +0,10 and a new cylinder liner liner to replace the broken one. Will give it to a machine shop to spindle out the barrel and shrink the new one in.
Then rebore both barrels for the new pistons.
Attachments navigator-cylinder-jpgWhen your primary case ins…
When your primary case inspection cap is worn and battered you can use one from an Commando:
https://andover-norton.co.uk/en/shop-details/15350/chaincase-inspection-cap-small-
Fits like a glove!
Here is my rear mudguard a…
Here is my rear mudguard after welding shut several holes in it.
I have some trouble getting it to fit right. I guess it is too short. Measurement across the top from end to end is 120cm or 47 inches.
The front end does not reach below the swing arm to the front fixing bracket when the rear end is in the oorrect height. Is it an origninal mudguard?
When Idismantled the bike there was another piece of mudguard bolted on the end. (See first post)
Can somebody please measure his original fender?
Sorry for the pics, my picture resize program somehow distorted them..
Attachments IMG_20161129_081136744.jpg IMG_20161129_082351928.jpg www.nortoIt's very difficult to ge…
It's very difficult to get a really accurate measurement with everything fitted on the bike but I reckon the length is 127cm or approx 50 inches. So your mudguard is too short; that why someone had fitted the extension in the first place.
The mudguard profile from the back looks very similar to mine but of course mine has the original style rear light/number plate fitted to it so you don't actually see a lot of the mudguard. See picture attached.
Maybe someone can give a more precise measurement.
Attachments P1080003.JPGThanks Patrick for your "r…
Thanks Patrick for your "rough" measurement.
Guess I?ll have to refit the extention . Looking at the pics from Ian Easton?s rebuild I don?t think I have an original rear fender.
Mine is cut out where the chainguard goes, Ian?s has a recess in that area. Anyway I?ll fit it since I have no other. The extension is barely visible down there.
Today I sent away my tank for paint removing in an acid bath.
The powder coating firm also offers this service. The man promised m a bare metal tank. I had to get rid off the cracked inner coating of the tank. We?ll see..
BTW: what size are the screws holding the tank side ornaments?
One is missing..
Petrol tanks are becoming…
Petrol tanks are becoming a problem as modern petrol containing ethanol attacks the old tank liners. It also attacks the old rubber pipe but that is easily and cheaply cured by fitting a new pipe which is made from a more suitable type of modern rubber. The latest tank liners now claim to be ethanol resistant but I have not had any first hand experience of using these.
The screws holding on the tank badges are 4BA to the best of my knowledge. This size is virtually identical to 3.5mm. In the UK household electric wall switches and sockets are fixed to their wall boxes by 3.5mm chrome headed brass screws and I have used these for fitting the badges as every household has spares of these. I'm not sure exactly what thread they have but certainly in my case they all screwed in easily. They are available very cheaply from any DIY store - certainly in England or Ireland but maybe not in Germany.
Patrick
Today I cleaned up the wel…
Today I cleaned up the welding spots on the mudguard , added the extension again and fitted it to the frame. It looks ok to me, the rear end not too high or too low. The license plate holder made in India was also mounted.
Boyer-Brandsen sent me a correct plate for the ignition. The previous owner used a Commando plate.
Attachments IMG_20161129_174433234%20-445x800.jpg IMG_20161130_154818338%20-800x427.Coming on nicely!
Coming on nicely!
That will look really good…
That will look really good when it gets a coat of paint - it follows the wheel line very very nicely .
Do you need to fit a reflector to comply with TUV rules ?
Interesting ! How did the previous owner fit a Commando ignition plate? Surely it is too big. The correct one to fit also fits the BSA Bantam 4 speed - info per Boyer. The one I have has worked perfectly for years.
Patrick
au contraire, mon cher! Th…
The Commando plate is smaller in diameter. It was put in in 1983, so I guess there was no plate for the Navigator available. The Navigator plate has a diameter of 76mm.
I have contact with the pre-pre owner, a guy from Belgium who imported the bike in 1983 as a non runner to Belgium from an elderly gentleman from north london .
He converted it to 12 volts and the Boyer ignition. He is about to look for photos etc. of the bike. So this puts a little light on the history of the bike.
Last time the TUV did not ask for a reflector when testing my Commando , so we?ll see..
Hi Uli, If you're looking…
Hi Uli,
If you're looking for a Lucas rear ligth lens, there is one on ebay right now, not really expensive.
Ebay-no: 162303375387
Fritz
Thanks Fritz, I have an or…
Thanks Fritz, I have an original one which I still in the box.
Previously peter_holland1 wrote:
So this tube has to be exchanged with a rougher one
Fritz
