I desperately need an Electra
Or rather, my right knee does. Anyone got one they'd like to shift? I promise I'd love and cherish it. tgrimwood1@gmail.com
Terry
Have you searched Ebay?
Or the Net generally?
There looks to be nothing on there at this moment in time!
You donât often see them in the Uk more common in the USA I think, but kick starting a navigator or jubilee is pretty easy, the compression isnât very high, you donât need to worry about getting it to tdc or anything, just push it around, and itâs only 175cc at a time!
Dan, probably has a very valid point there, three to four years ago prices were almost half of what people want now!
Yep! if you check the production figures nearly all went out to the good "ole" USA, maybe Australis too!
Try this search engine pricecat.co.uk for home sales and if you do try Ebay make sure the Worldwide box is ticked!
I got my Electra from the USA in bits. I would not rely on the starter to much I never did get mine to work properly. I also have a Jubilee and find these bikes when fitted with electronic ignition are very easy to start. I did have quite a bit of trouble with the Jubilee before giving up on the points system now its mostly a first kick starter. Bryon
