End of a total rebuild in sight...BUT my dismantling notes and bags of parts have let me down on the assembly of upper/lower yokes and steering column. Amongst the bearings, middle (head race adjuster)and upper (fork crown column) nuts and large metal washers I have found a composite washer (seems almost like bakelite, not fibre, not felt, not metal).
The inner dimension is a tight fit on thr steering column (you need to twist it round the screw threads) the outer dimension matches the frame headstock tube. Only possible place it would therefore appear to fit is under the bearing on the lower fork yoke.
Nothing like this washer appears in either the Haynes manual(187) or the Norton parts list illustrations.
Any ideas?
Will add the fact that although the fork legs have in past been removed for repair/replacement the yokes/steering column setup has never been disturbed, so the assumption has to be this was factory fitted....OR have I stupidly bagged this washer with entirely the wrong bits ?. If so any idea where irt should go? (polite answers only !!)
Thanks, JMB
It sounds to me like it co…
It'll have asbestos in it…
It'll have asbestos in it so don't lose itbecause you won't find another the same...legally.
Previously john_baker2 wro…
Any ideas?
Thanks, JMB
hello but the thing is how many times as these fork been rebuilt and who as been doing the work, this like most bike you get that had multiples owns and what have they done with the bike in there time of ownership yours anna j
Previously Gordon Johnston…
Previously Gordon Johnston wrote:
It sounds to me like it could be the friction disc from a steering damper. Gordon.
Ah yes! that seems likely Gordon, thanks.
So it does go under the bearing on lower yoke. Is this something that Norotn would have fitted regardless of whether or not a friction damper was being added? or maybe its a 'tea break' moment and only half a job done.
regards JMB
hello but the thing is how…
Agreethe point you make...but...I'm second owner almost from new.
regards JMB
