Hi to all - looking for input on this from those more well versed than I.
I have recently rejoined after a few years absence. I purchased a 1956 Dommie 99 basket case some years ago when time and enthusiasm were both more abundant. I am finally getting back to my Commando project but have always wondered about an aspect of the Dommie frame .
The rear most lower crossmember of the frame has very rough outboard ends on the frame loops .
Can anyone tell me if this is normal ? They appear to have been welded up or brazed in some fashion.
Hopefully I will be successful in posting a picture. Thanks in advance for any help - Cheers - Richard
image-jpg
Yes, they've, been brazed…
Can anyone post a photo of…
Can anyone post a photo of what this area should look like ? - thanks for any help
Cheers - Richard
Previously richard_tool wr…
Hello well I should not be too concerned I would smooth this out by using a flapper wheel on an angle grinder but use it with care and I must stress use the right protective clothing and gloves and eye protection and work in a well-lit area your health and safety comesfirst and safetyof other too so put a sign that your working and keep childrenaway from any work area and cover up anything were the sparkes are going to go these are like hot mini bullets and will burn anything that will chatch fire like your skin your anna j
As no one else has posted…
As no one else has posted a photo here are a couple from my 1958 Model 88 Dominator. Of course this may be different from how your 1956 should be I cannot say for certain.
dominator-39-jpg
and a second shot (I am no…
and a second shot (I am not sure what I do wrong but I don't seem to be able to add more than one photo to a comment)
dominator-38-jpg
Thank you Michael- It seem…
Thank you Michael- It seems that some frames have no boss on the outside opposit the crossmember and some have what appears to be an open tube/ washer appearance. Puzzling
thanks again - Richard
I'm just guessing now, bu…
I'm just guessing now, but some frames were made of thinner tube (inters?) and may have needed a different method?.
My 1955 model 88 frame has…
My 1955 model 88 frame has the washers on the end. Featherbed frames had various changes to them over the years. I am not sure when this detail was done away with, I think 56/57.
Guesswork, but maybe someone tried to attach rearset footrests to it at some point in its life? As Anna said, just clean them up.
I would be more concerned about the several holes which have been drilled in your frame; visible in your photo. They will seriously weaken it.
Ian
Robert and Ian - Thanks fo…
Robert and Ian - Thanks for the help and important observations. Come the day I may start on this project my first priority chassis wise is to check alignment - judging by the state of some of the components it has had a pretty rough life- ( evidence of thrown rod , broken fins on cylinders, etc ) . If the frame proves worth the effort then I will look to welding up the holes , etc.
I thought the same regarding rear sets , etc. This was won on e bay and I drove 9 hrs to pick it up -
only then were the engine issues disclosed. It had a clear and valid title and that is where the value lay to me so I bought it - they don't come up very often in my part of the world and as I was full of enthusiasm at the time I thought I would enjoy the challenge of trying to save it - it is a Wideline featherbed after all and I'm sure if you are reading this you know the sentiment part . Meanwhile I've a 1972 Combat Roadster to finish up.
Thanks again to all for the responses.
Cheers - Richard
It may be that the frames…
It may be that the frames with the boss on the bottom rail were built specifically for sidecar use and this was an attachment strong point.
Looking along the frame there appears to be drilled holes which can not help the strength. Plus any water that gets inside this rail will soon cause it to rot through.
Phil. Mine has small holes…
Phil. Mine has small holes drilled through the'washers' on the end of the cross tube which appear original, but nowhere near large enough for the size of bolt needed for sidecar attachment. There has been much discussion over their purpose since I acquired the machine 11 years ago, including at length with Peter Scatchard; who seems to have fair knowledge of the differences in Featherbed frames; some years back on the IoM during a Norton rally, but without conclusion. Maybe they were factory-drilled pilot holes to ensure correct alignment in the event that a sidecar is fitted? That would involve drilling them out oversize, and I cannot imagine the factory would think drilling their frames was a good idea, although they are in effect only washers, which are not adding to the strength of the frame. The tube alone provides the strength. Also, the exhaust pipes are in the way, which would mean using siamese pipes exiting on the right, which in itself is quite feasible. Anyway, they were subsequently done away with.
Previously ian_cordes wrot…
Hello my 1954 featherbed Dominator as the same frame set up and this bottom cross tube as nothing to do with a sidecar fitting has Norton Built the Model 7 for this perprose, Norton did Not reconmend fitting a side car to the featherbed frame,
yours Anna J
Previously anna jeannette…
yours Anna J
In fairness,although Norton were sceptical about sidecar use, they did supply featherbed bikes with sidecar trail forks and a certain Eric Pliver and Pat Wise did prodigeous things in the IOM TT with a 88 Dominator with a road going sidecar.
yours Anna J
Yes, I know that Anna, but as Charles said, sidecars were fitted to Featherbeds, and Norton made provision for that with the forks.
Instead of saying what they are NOT for, can you tell us what they ARE for, as you are the font of all Featherbed knowledge?
Ian
Font of nothing much at al…
Font of nothing much at all......more like! Cheers Howard
BTW my mate has an origina…
BTW my mate has an original, never been painted, rebuilt or anything much apart from routine maintenance 1957 Dommie 99, and it has that detail on the frame. I am pretty sure the last of the Widelines didn't, so maybe his was the last year before it changed?
Hi Richard, Further to pre…
Hi Richard,
Further to previous comments and now that I have had time to take some photos of my 1958 99, it isn't a washer but a flanged bush.
The overall length of the bush is 5/16" with o/d of 1-1/4" and bore of 5/16" with a flange length of approx. 0.1".
the face of the flange stands 3/8" off the main tube side.
The main cross member has 'saddled'ends, where it fits against the main frame tubes, then welded.
The outer tube with, theflanged boss, is also saddled and welded. there is no evidence of weld between bush and tube so it must be pre-welded on the inside prior to being welded to the main tubes.
The 5/16" bore does not go thro the main tubes.
Both sides of the frame are identical.
I can only imagine that they were added as alignment aids when the frame was in the welding jig.
As the earlier comment someone has tried to add something so it would not be detrimental to just grind them flush.
I have hopefully attached 2 photographs but have more if anyone is interested.
Dick
035-jpg
Obviously I don't know ho…
Thanks to all for the inpu…
Thanks to all for the input - I was just about to post my thoughts on the possibility of it being part of a fixture for frame assembly when Dick posted the same thought .
Dick - Thank you very much indeed - exactly what I need - dimensions and all !
I have always used the term saddled regarding the cut in the end of a tube where it meets another but some on this side of the pond refer to it as a " fish mouth " so more of the petrol / gas ,
hood/bonnet sort of thing .
Cheers - Richard
Richard H. Thank you for t…
Richard H. Thank you for the very interesting and detailed description. My assumption that it was drilled right through puzzled me, as it could let water in, causing the tube to rust from inside. You have answered that!
It does seem quite a clumsy method of alignment, given the otherwise graceful lines of the featherbed frame, with no forged lugs etc. Certainly another method was found, as this detail disappeared, if not on the last of the Widelines, certainly on Slimline frames.
Good info!
Richard T. You can now get your flap wheel out and dress it back, even drilling a 5/16" hole to a short depth for authentic appearance, maybe?
Ian
Yes, they've, been brazed/welded like you say. The crossmember tube normally has like a a washer welded into each end. If no-one else puts one up I'll try to get a photo later.
Cheers.
Ian.
