Cylinder block distortion
Anybody had experience with aluminium alloy barrels fitted to Commando's. I have a set from Steve Maney which after 7,000 miles have distorted by upto .002'' adjacent to the through bolt cap heads, on the inside of the bore. After talking to Steve Maney he suggested that I had over tightened the bolts, possibly due to my torque wrench being out of calibration, fair comment as it is approx. 30 years old, but only seen DIYuse and it is a Britool. Bolts were torqued to 25lbft.
I should mention thebolts are stainless steel, which whilst having ahigher coefficient ofexpansion than 'ordinary' steel, it is significantly less than aluminium alloy. Thus when the engine is hot pressure at the cap head contact points increases, possibly causing distortion. Does anybody know ofa design of boltwhich will stretch to accomodate the difference inexpansion or of a suitable material for the bolts.
I've thought about reducing the torque figure and also reducing the diameter ofbolt shank as is common practice on con-rod bolts andcylinder block/head through bolts on more modern engines. I will also check the accuracy ofmy torque wrench, but any help in the mean time would be appreciated,
Cheers, Simon.
What bolts does Steve Maney recommend, and does he suggest a different torque figure? 25lbft doesn't sound likebeing massively stressed (even if your torque wrench is out,) but I would have thought that Steve would be best placed to comment on this.
As far as reducing bolt shanks, like conrod bolts, is concerned, I thought conrod bolt shanks were the required thickness for the application, and the larger thread was so that the diameter of the bottom of the thread was not less than the diameter of the shank. If so, reducing the shank on your through bolts may weaken them too much. (Only a layman's understanding, mind you, and I'm sure there'll be an engineer along soon to clarify!)
Get some alloy bolts Simon, then they will expand at the same rate as the barrel. You can probably get some good ones on ebay! Or at your friendly Norton dealer! Joking aside, Stainless steel bolts will have cut thread as opposed to a high tensile bolt's thread being rolled. Stainless tends to gall and could be responsible for giving an incorrect torque figures, ( that may be why many car engines now use degrees of rotation rather than torque for tightening bolts) I have access to digital torque wrench test kit. drop your wrench round and I'll test it for you. If you hadn't bought that damned bore gauge, you'd be none the wiser, ignorance is bliss.
Dave
Steve Maney supplied the bolts with the barrel and recommended 25lbft torque. The distortion became apparent when the head was off to replace the Andover Norton pushrods I'd fitted earlier in the year, becauseof two loose steel caps on two of the rods.These have been returned to TMS, who have refunded me but had not returned the rods to AN last time I spoke to them.The distortion was discovered whenthe bores were checked with a Mercer bore gauge to see how they were wearing.
I'm beginning to think the aluminium alloy is not compatible with theoriginal cast ironcylinder through bolt design, so it makes me wonderon the condition of other Commando'susing alloy blocks.Cheers for the offer Dave, I'll drop the torque wrenchoff,
Simon.
Have you checked the bores with the head installed and bolts tightened.Bores allways distort to some degree when adjoining bolts are tightened,then the high spots wear off,leaving round[ish] bores in service.Through studs are used to eliminate bore distortion.Regards John.
This looks like it might be a bit more common than envisaged, but as John says, distortion will be present to some degree or another. What does seem a pity is that the engine was dismantled to replace the push rods - now I wonder why TMS have not returned them AN.
I always like to hone these types of cylinders, with a set of torque plates, heated with warm honing fluid.
Assembly engine, when tighteningWarm engine with a heat gun and torque cly/heads, use proper sequence.Run eng upto temp, stopand break fasteners and re-torque hot. You require high grade steel studs/bolts with rolled threads or risk failure.
Regards Ian.
Using torque plates makes sense for the cylinder block, especially aluminium alloy as I've learnt from the problemsexperienced with this block, and torqueing the bolts with a hot engine makes sense too, but wont the damage, i.e distortion due to expansion coeeficients between different materials, have already been done if the initial torque settings are with the engine only warm? You would also have to remove the hot head to gain access to the cylinder through bolts, which in my opinion are the cause of the problem. Also I suspect oil/combustion leaks may be a problem until the engine reaches operating temperature. I'm not a fan of RTV especially were oil ways are present.
Thanks for the advice Ian, what are your experiences with alloy cylinder blocks on Commandos, road or race?,Have you experienced problems with leaks or distortion?
Cheers Simon.
Cheers Simon.
Hi Simon,
Sorry, if I was not very clear or miss-understood,is your block already distorted, if so it's leaking or smoking, and you will have already removed it, and you can probably see the uneven wear pattern.
This has been an ongoing problem with bike engines, especially since more and more parts, started being made of different alloys, looking for more power.
I remember it really becoming a problem with high perf Harley engines in the early 80's, and I think/remember that's where using torque plates really started and/or took off. I certainly cannot remember much discussion on the issue before that. I/we had a dunstall barrel about the same time period and they were quite notorious, for twisting and leaking.
I used the word "warm" because I do not want to be sued, because someone really keen somewhere, scald's themselves with boiling oil.
If you stick a good quality Iron/steel sleeve into aluminium it's going to shift, especially if it has not been thru a few heat cycles. Add in not loaded in the way it is going to be ,and it's going to be more of a problem. A reason why a properly made all aluminium nikasil block with good rings is a much better solution, all be itabit more expensive. The correct grade of aluminium sleeve must also be used, or the plating departs.
Here is what I am going to do with my own brand new aluminium cylinder formy own latest850. I am not assuming someone loved it like me.
I am going to take my 850 alloy barrell and make sure that the cases base to cly surface is flat and square to one another and then,that itis to the crank. Now check the head surfaces to one another they are flat and square .
I am now taking my 1 inch thk aluminium torque plates, and I am bolting it all together, using some high temp grease on the presure surfaces, and some light grease or light oil on bolt threads, personally now I use torque lube because I have some. Torque it up as per sequence, if the specs are dry that you use, add 2ft lbs if now lubing. Taking this assemblyI stick it in the oven, and then outside to cool, Fromaround 200-220deg F, anymoreand you can change heat treat of aluminium parts permanatly. repeat 2-3 times, I use the 3 times lucky rule. Check it hot and when cooled after removing torque plates,for round,If the surfaces are still flat and square, you are ready for honing. Put it all back together, warm it up again, and warm your oil. depends on how you are doing it and with what. I have a lise 4 stone set hone and a bobilie ball hone for finishing, if you are dipping it in fluid that's different to a flowing a source of lube, and you have the boiling point of the fluid to consider to, you don't want more than you have, to have flashing off and killing you softly, We are trying to replicate running conditions, for the final honing, as best we can.
Now your mating surfaces should be still square, and flat, but your boremay seem a little off when cold and not torquedbut good when torqued &hot.We are looking for within tolerance, at it'sbest when simulating conditions. We are never going to truly achieve this because of moving parts and changing pressures, within the cylinders.
I am assumming your barrel is off right now, andif you don't have access to torque plates, bolt it up with the bare head and cases and try it in the oven a couple of times to make sure it is not moving anymore. Remember about the temp limits so as not to damage your parts.
I do not use base gaskets, unless I am shimming for head clearance purposes, shouldn't apply to you, then I use solids for the thickness I want. IUseREAL Rolls Royce, Hylomar blue, they have a new race one now as well, it seems a bit thinner,but stands slightly higher heat, make sure of oilways, it's not like other sealants Thats for the base. On the cylinder head I use solid copper, or other metal types, on high perf. Norton or norvil best quality steel flame ring gaskets are fine on stock engines. I coat them all with copper slip, sparingly it goes a long way. Torque it all down in sequence, now run it ride it a short distance, put some loads thru it. break the nuts, bolts, studs or hex bolts whatever you are using just enough to release the tension in them, in reverse order of torquing sequence and retorque them, I do them hot if I am using copper/metal gaskets, and if I have played with the head in anyway, cold is fine for regular gskt andpurposes. done correctly it is not going to get any better. You are starting off from cold with no stress in the motor, cases and cylinder are relativly thin mat'l next to that lump, I don't worry about the internal bolts, it's all aluminium now and when hot, the lower rate bolts should only add a compressive load. If your really worried about that do them up with everything naked and check with a bore gauge. Even warm it up and check. I don't see it.
With your distored barrels, they have moved in accordance with the internal stresses placed upon them, and within them. I cannot tell you what they will do next, only that bolting them up and putting them thru some heat cycles will do that, how many have they already been thru. Then correct them once they have settled. square them to the cases/crank, then head to that. Now warm up the bores and simulate the loaded barrels to the cases, and distortion caused by that giant chunk called a head.
I once shaved 1/2 inch off a set of500 barrels rewelded the center drilled and tapped it, andused this method to tighten it, it does not have a full face, it's 10.5:1 and it does not leak, and is 750 quick, I've built racers, but not much lately due to gimphood. This is the way I do my bikes and my buddies bikes. I am building my ideal 850 at the moment, all out of bits, I"ve considered removing the steel liner and getting an aluminium one to press in, then sending it off once it's settled, for coating, but at the moment I'm sticking with the steel, to spend my dosh on other parts. It's never going to be perfect somewhere, as your running hot I hope,and gently when cold, I know what I prefer. The bike doesn't know it's racing.
I Hope that gets it, I've pressed in a good few sleeves and they move around untill they settle. I don't know who made yours, but ? are they cast in sleeves like old jap bikes, or cast barrels, then bored and the sleeves pressed in,If sodid they leave them in the press for a while after pressing, did they use a pressing oil, have they already cycled them. There are so many different ways you can do things, that affects them for stress relieving , before we go re-stressing them.
The way I look at it, once the only thing made of steel that's stationary, is the sleeve, your problems should be fewer, true different grades of aluminium can expand at different rates, but once you have run it and retorqued it, it shouldn"t move again. You retorque the head to allow the parts to re-align themselves from the running stresses placed upon them.I don't feel that's aconcern with the case to barrels joint. If your worrying about bolts putting loads thru the aluminium, I think not, all cylinders would fail and you should be able to trouble shoot it.
What makes you think they are distorting, I recently had a problem with a buddie's BSA, the cylinders were bored out of alignment, with the crank.
Sorry this is a novel, hope it help's
Regards Ian
Hi Simon,
I do not know how you are checking for distortion,but If you have the engine apart install the cylinders to the crankcases and pop them in the oven to around 180-200deg F, If the distortion is from the bolts it should show up. I have a set of 850 Maney barrels for my latest project. I've have had fair spares barrels good, and dunstal barrels. I don't have much complimentary about those, but I did make them work and liked the cam followers, that everyone has copied.
If you use real Rolls Royce Hylomar instead of a base gasket you won't have any problems there, and barrels can rock and deform on soft base gaskets, I never use them on British twins,or harleys.I have not had a leak or an oil problem in over 30 yrs.(ever) It's not a silcone type sealant and never hardens or clogs with oil. Although I do always check the drain type oilways. Aircraft safe, the only one, blue.
The expansion rate of stainless is similar to that of aluminium but not as strong as high tensile steel, so I certainly wouldn't neck it down, the load when hot will be tensile on the studs so thinner if anything. By the way the kind of bolts/studs you are talking about are high tensile Rolled, which makes them as strong as they can be and the threads are larger so as to not over work the threads,plus if they do break from over torquing, they go above the threaded section.
The joint between the cases and barrels is now all aluminium so you really don't have to worry about that. The pressure waves occur in the combustion chamberwhich is the reason for retorquing the head, to relieve the strain on the head/gasket joint. I always use copper slip on the head gskt, I usually use copper or metal on high perf. The regular steel flame ring high quality stock gskt is fine and easier to get a good seal with for stocktype engines. Copper slip both kinds sparingly a little goes a long way, and allows the gskt to slip and bed in. I build both road and race.
Regards Ian
Sorry That's a double answer there the first didn't upload and then did, 2 for 1 today only.
Ian
Thankyou for taking the time to replyIan, once again much of what you say makes sense regarding heat/stress cycles and effects andengine assembly.
I've decided to revert back to thecast iron barrel as I'd never had any problems before.... until it required a rebore. One cast iron barrel is having work done on it and I'll have to wait and see if theguy doing it is as good as his word. I may be swapping the alloy barrel for another cast iron barrel, so at least I'llhave another chance of finding somebody who can do the job properly if necessary.
Cheers, Simon.
Further to my first message on this subject. I've had my torque wrench accurately calibrated (cheers Dave). At an indicated 20ftlb it is producing 19ftlb, so at 25ftlb it will be under tightening not over. Therefore I conclude that the through bolt alloy design will distort due to the alloy block expanding at a greater rate than the through bolts,causing distortion of the bores and a loss of cylinder pressure.
I'm sticking with the cast iron version,
Cheers Simon.
