Hello,
What is the length of origin spring who is in the valve body pressure on the crankcase of distribution for 850 MK3 ?
Thank you,regards Francis
The relacement springs are…
Thank you very much Phill…
Thank you very much Phill for your quickly answer.
For my MK3 the relacement spring are 30 mm and there is a shim like the part-list
Regards,Francis (french member)
The relacement springs are 1.171" or 29.743mm. The earlier pre-mark 3 engines used shims to help get the correct pressue valve release value. I believe that the mark 3 just relied on the spring length being correct.
